Plotting to PDF- stopping PDF layers from showing/ plotting
MAREBER
Hello again,
I normally plot to 'DWG to PDF.pc3'. I have not had issues in the past with layers also being plotted with PDFs, but my old PC died and I am now on a new PC that is outputting PDFs with layers.
I have tried going into CAD properties and also Adobe properties with no luck as of yet.
This is one of a few glitches that I am trying to figure out. So any advice would be lovely.
Also, while I am on the PDF subject, I would like the plotted PDF to open automatically. Can someone help me to find that adjustment as well?
THANKS!
Hello again,
THANKS!
Publish Options. Command >_PUBLISH, Publish Options button. Each line has a dropdown choice for you to use. You can do the same to your Automatic Publish Options if you use that method. You can find the Auto Publish Options by Command > OPTIONS, Plot & Publish Tab, Automatic Publish Options Button.
1+ for the Autopublish mechanism, as it allows me to use DWG to PDF to produce PDF each time I save my work, and it does so much faster than either PLOT or PUBLISH. :thumbsup:
I guess I should check out how Auto-Publish actually works. There has been at least one time that I could have used a date-time stamped document trail of some sort.
It's really quite simple - set the options you want, such as DWF/PDF, Include Layer Info?, and when to produce at Save or Close - and setup a default named Page Setup.
After that, you literally just do your work.
To help make adopting Autopublish a bit easier, as it can be quite a PITA to manually apply the named Page Setup to each-and-every-single Layout manually, I wrote this little ditty to expedite the task which can also be used with ObjectDBX for batch processing a directory of drawings at once:
http://forums.augi.com/showthread.php?80461-Page-Setup-Manager&p=1219546&viewfull=1#post1219546
Example:
(foreach layoutname (layoutlist)
 ([color="red"]vla-SetActivePageSetup[/color] layoutname “YourPageSetupName”)
Example:
Thx, I'll have to take a pass on the code since I am running LT, but my MO is draw a page, set up a page, so the only thing I'd have to change is to name and save my set-up for each one as I go, I suppose.
Thank you both-
but neither one of these suggestions has solved my problem- not sure as to why because I tried to do the same thing you have suggested before I posted. (change plot options)
I am still getting layers with each plot and it is not automatically opening.
Perhaps I need to restart CAD to save these changes?
Since you did not mention anything about publishing, I'm not sure why these guys would mention it as a solution to your question.
The settings you are looking for are located in the printer settings as shown below:
Thank you so much! That took care of the auto layers issue. Although even though checked, as shown above, the PDF will not open automatically.
One more question, how can I stop the creation of a plot log with every plot?
Thank you Rob. I unchecked that and it is working now. PDFs created with the plots are still not opening automatically though. I must be missing something?
For some reason I have yet to work out, even with those settings unticked I still get layer information in the PDF.
