Dimensions in a custom template
So for work we run a custom template with a specific dimstyle. For some larger drawings, dimension styles such as text height and scale are changed. When trying to copy these drawings into a new dwg file, it doesn't keep the dimension style of the original drawing and the dimensions get all messed up. Is there a way to keep the dimension style when copying and pasting other than manually changing it? Also, with the text style Romans, I am unable to change one specific dimension text height like I can with the standard text style, is there any way around this?
Thank you!
(AutoCAD LT 2009)
Give the dimstyle a unique name before copying.
Set the assigne height to zero.
