Brewbrae Posted August 20, 2015 Share Posted August 20, 2015 I have reinstalled my AutoCAD 2004 program running on Windows XP. It is working fine, but some specific commands eg. PROPERTIES, MATCH PROPERTIES and one or two others are not being recognised. Can this be sorted in the program settings? Thanks Quote Link to comment Share on other sites More sharing options...
SLW210 Posted August 20, 2015 Share Posted August 20, 2015 What method(s) are you using to start the commands? What is shown on the commandline when you try to use one of those commands? Try resetting your profile in Options. Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted August 20, 2015 Share Posted August 20, 2015 Also, when you fire up AutoCAD 2004 from scratch, press F2 and review the command line history. Are there any error messages? Anything that would indicate something out of wack? Sounds like maybe some support files are not loading. Quote Link to comment Share on other sites More sharing options...
Brewbrae Posted August 20, 2015 Author Share Posted August 20, 2015 Thanks for your post. The command line says "unknown command-press F1 for help". this happens with both a toolbar command or typed command. Quote Link to comment Share on other sites More sharing options...
rkent Posted August 20, 2015 Share Posted August 20, 2015 It sounds like the Demandload setting, type that in and set to 3. HTH Quote Link to comment Share on other sites More sharing options...
Brewbrae Posted August 20, 2015 Author Share Posted August 20, 2015 Hi, Demandload was already set to 3. If it gives any clue the commands not working are: PROPERTIES, MATCHPROPERTIES, ADCENTRE, TOOLPALETTES, +DSETTINGS (snap), RECTANGLE, REVCLOUD, LAYERP. Thanks Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted August 20, 2015 Share Posted August 20, 2015 I don't have access to 2004 any longer but that sounds like a startup file (acad2004.lsp, or acad2004doc.lsp) isn't be loaded. Hence my earlier question about any abnormalities at startup...... Quote Link to comment Share on other sites More sharing options...
rkent Posted August 20, 2015 Share Posted August 20, 2015 Maybe look in Options, Files, Support File Search Path and copy and paste that so we can look at it. I assume you have tried: 1 Restarting AutoCAD, 2 Starting AutoCAD with a different profile, 3 Tried a different Windows profile to start with, 4 Ran the repair option for AutoCAD? Quote Link to comment Share on other sites More sharing options...
SLW210 Posted August 20, 2015 Share Posted August 20, 2015 Hi, Demandload was already set to 3.If it gives any clue the commands not working are: PROPERTIES, MATCHPROPERTIES, ADCENTRE, TOOLPALETTES, +DSETTINGS (snap), RECTANGLE, REVCLOUD, LAYERP. Thanks Try (load "acad.mnl") on the commandline. Quote Link to comment Share on other sites More sharing options...
Brewbrae Posted August 24, 2015 Author Share Posted August 24, 2015 I have reloaded the programme from scratch and it appears to be functioning fully now. Thanks to all contributors for their help. Quote Link to comment Share on other sites More sharing options...
