Results 1 to 5 of 5
    Forum Newbie
    AutoCAD 2016
    Aug 2015
    3
    Unhappy How do I approach this? - 3D Ergonomic Cup
    I have designed the Cup part, however I'm having a hard time on how to approach the handle part of it. I plan to design it in 2D and then use revolve, but I'm stuck on the 2D part... How do I make all those curves perfectly? When using circles I can't quite find the perfect alignment and I get lost in the process...
    Any help would be greatly appreciated, Thanks!
    <Autodesk AutoCAD 2016>
    AutoCAD 2013
    Nov 2011
    5,985
    Welcome to CADTutor.
    Draw the left half of Section A-A, as a CLOSED POLYLINE, then REVOLVE it about the center axis, to create the cup shape, as a 3D Solid.
    Then draw the handle as shown on the right half of that same view, again as CLOSED POLYLINES, and EXTRUDE it to create the other 3D Solids you will need.
    You can use the 3DALIGN command when it comes time to put the bits together.
    You will probably want to use an isometric perspective when doing the modeling, at least some of the time.
    Forum Newbie
    AutoCAD 2016
    Aug 2015
    3
    Quote Originally Posted by Dadgad View Post
    Yeah I'm already done with the 3D Cup, but my actual problem is the Handle since I have no idea at which part to start and how to make sure that I get accurate curves. I guess I can make circles with the given radiuses but putting them together is where I'm stuck at.
    Forum Newbie
    AutoCAD 2016
    Aug 2015
    3
    Really need help... please..
    DWG file:
    https://app.box.com/s/d2qwz7cjl5moznunrpa3u9w66bj9bc3l
  5. #5
    Luminous Being tzframpton's Avatar
    tzframpton's Computer Details
    HP Zbook
    Multi-disciplinary
    tzframpton's Discipline Details
    BIM Specialist
    Multi-disciplinary
    Full Virtual Design and Construction BIM services for the MEP engineering and construction industries.
    Revit 2018
    Mar 2006
    Dallas, TX - USA
    9,067
    It will be hard to get them perfect since the picture doesn't give you the location of the centerpoint of each arc. In the 3D view, I can see hard edges between the arcs so I don't think it's as fluid as you may be thinking. Curves that are completely tangential will not have these hard edges where the handle is.
    I think the radius arcs are simply for general reference. So make circles, and place them close to the layout, making sure the lines touch or slightly overlap even, then use TRIM to create the profile needed. Finish up with the rest of the handle, then EXTRUDE it to the desired thickness, and move in place then use the UNION command to join the solid geometry together.
    But to have perfect placement of each arc, you'd need more information as a beginner. And I'm no mathematician: there may be someone here who can figure that part out, but the point of the exercise is to model a cup, not to mathematically decipher the placement of tangential arcs.
    My $0.02 worth anyways.
    -TZ
    Tannar Z. Frampton ™ | Frampton & Associates, Inc.
  1. Ergonomic Knife in AutoCad2012 - Big Problems!
    By duggibobo in forum AutoCAD 3D Modelling & Rendering
    Last Post: 25th Feb 2013, 06:27 pm
  2. How would you approach this? Lofting?
    By spittle in forum SolidWorks
    Last Post: 15th Jan 2009, 08:54 pm
  3. What would be YOUR approach to do this?
    By marlon in forum AutoCAD 3D Modelling & Rendering
    Last Post: 29th Nov 2008, 12:41 am
  4. Approach to designing in 3D
    By Siberian in forum AutoCAD 3D Modelling & Rendering
    Last Post: 13th Jul 2007, 12:54 am
