gotchy Posted August 21, 2015 Share Posted August 21, 2015 I use Solidworks v 2007, and when I am in the Sweep feature, and need to select the path and profile in order to perform the sweep this window pops up. Please tell me which selections I need to make in order to select the path and profile. See attachment. Gotchy Quote Link to comment Share on other sites More sharing options...
Writz Posted August 21, 2015 Share Posted August 21, 2015 you should select the sketch that identifies the profile/thickness of the sweep in the green one (ex: circle, square) and select the route/path of that sweep in the pink one. I suggest you use a newer version of solidworks, so many things changed in solidworks in 8 years. Also, I recommend this amazing book "solidworks: no experience required" Quote Link to comment Share on other sites More sharing options...
shift1313 Posted November 2, 2015 Share Posted November 2, 2015 The popup is the selection manager. The 4 options on the lower left let you do things like select a region, chain or manual selection. Ive never used 07 but the selection manager still looks very similar. Search your help file for it. Quote Link to comment Share on other sites More sharing options...
