Results 1 to 8 of 8
    Forum Newbie
    AutoCAD 2016
    Aug 2015
    2
    Default Identifying 3D Cartesian Coordinates
    Hello,
    So I've been creating 3D structures for a little while, but when I create an object, the identification system asks me for (say I'm making a line) the x&y of the initial point, then the length and the angle to make the second point. It always assigns the z coordinate at 0. How do I change it so that I can identify the start and endpoints using x,y,z terminology?
    The 3D polyline allows me to do this for the first point, but not the second. And I'm not sure how to do this for other shapes.
    AutoCAD 2013
    Nov 2011
    6,056
    Welcome to CADTutor.
    There are quite a few options avaiable for setting up your Dynamic Input preferences.
    Hopefully these screenshots willl help you to set it up how you like it.
    AutoCAD 2013
    Nov 2011
    6,056
    I just found one more system variable setting that will likely make you happy.
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,179
    When entering coordinates, AutoCAD assumes a 0 Z value unless you specify one. If you like to draw by entering coordinates, just add the Z value to your string but there are easier ways to draw in 3D for most.
    Drafting is a breeze.
  5. #5
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
    Attach a copy of the drawing to your next post so we can see for ourselves what you are doing.
  6. #6
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    16GB, 1600MHz, DDR3 non-ECC 2x8GB
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2017
    Nov 2007
    4,598
    Quote Originally Posted by lorims View Post
    Hello,
    .... How do I change it so that I can identify the start and endpoints using x,y,z terminology?
    Simply enter
    10,12,24
    at the command line or DynInput prompt.
    You should learn about x,y,z filters as they are very helpful in 3D as well as 2D.
    Start a line command,
    enter .xy
    pick a point
    now it will ask for Z
    enter a value, continue from there.
    You can also use .z first and then continue, etc.
    Sometimes there's a man... I won't say a hero, 'cause, what's a hero? But sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place. He fits right in there. And that's the Dude, in Los Angeles. - The Stranger, The Big Lebowski
  7. #7
    Forum Newbie
    AutoCAD 2016
    Aug 2015
    2
    Thanks all! When I'm specifying a third point for the 2nd endpoint of a rectangle (say first point is 0,0,0, and I want second point to be at 1,1,1) It says "2D point or option keyword required." Is there a way to get around this?
  8. #8
    Forum Deity steven-g's Avatar
    steven-g's Computer Details
    Win 7
    Construction
    steven-g's Discipline Details
    Draughtsman
    Construction
    I work in the estimating department of a large building contractor.
    AutoCAD 2018
    May 2013
    An Englishman in Belgium
    2,165
    Nope, not directly, a lot of autocad geometry is linked to the current ucs, so you can enter a start point anywhere in 3D space but any further points have to be parallel to the ucs, this goes for polylines (rectangles), circles etc, the "line" command is free from this restriction as are 3d polylines. The only way you can get around this is to change your ucs to match the new drawing plane or first draw the object and then use the align command.
  1. Database for identifying cables
    By richard3009 in forum AutoCAD General
    Last Post: 28th May 2014, 07:36 pm
  2. identifying object
    By honey in forum AutoLISP, Visual LISP & DCL
    Last Post: 4th Nov 2009, 02:18 pm
  3. ploting using Cartesian coordinate system
    By cordgrass in forum AutoCAD Beginners' Area
    Last Post: 18th Aug 2009, 03:43 pm
  4. Arc - Cartesian Coordinates
    By cibola in forum AutoCAD Beginners' Area
    Last Post: 23rd Jul 2009, 12:18 am
  5. identifying an object's layer
    By CLC in forum AutoCAD General
    Last Post: 18th Dec 2005, 10:25 am
