Dimension
DuanJinHui
Hello friends.
I want a Dimension like this .
1. Pick a line (centerline)
2. pick a point
Pick a line and one point , Calculate the other point , ps. this centreline is mirror line , so easy get other point .
Two point , use _dimaligned Dimension ............
Properties changes.
Need a Option , Need diameter symbol ? choose yes or no , if choose "yes" , need text override. like this:
This is what I need .
Thanks a lot.
Edited by DuanJinHui
explain clear
Where does the diameter resides ? is it a value of Xdata attached to an object or what ?
Dear Tharwat.
Not Xdata, only use "Rotated Dimension"
Hey, dude , not need use trim
But , I don't know how to do this use lisp .
as an electrical dragon I don't use dimension often , hopefully an mechanical dragon can answer your question better
Label the Linear dimension 15. Anyone who gets the "Half Section Cut" will understand the 15. As their is no circle shown or even endpoints to support a Linear dimension of 30 your "This is what I need" dimension is confusing at best.
Mechanical Drawing Standard book
Maybe need a Option , Need diameter symbol ? choose yes or no
[ATTACH=CONFIG]55354[/ATTACH]
Sorry, never done Mechanical work. I imagine a Mechanical vertical would have that, there's an endless amount of stuff in Civil 3D you cannot do with vanilla AutoCAD.
electrical & mechanical at this Thread is not important ,
just Pick a line and one point , Calculate the other point , ps. this centreline is mirror line , so easy get other point .
(defun c:dimdim    (/ cline pt1 pt2 pt3 dis inp dimtext)
 (if (and (setq pt1 (getpoint "\nSelect outer point"))
      (setvar "lastpoint" pt1)
      (setq cline (cadr (entsel "\nSelect centerline"))))
     (setq pt2 (osnap cline "per")
       pt3 (polar pt1 (angle pt1 pt2) (* 2 (distance pt1 pt2)))
       dis (rtos (distance pt1 pt3) 2 2))
     (Initget "Yes No")
     (setq inp
        (getkword
          (strcat "\nEnter distance (" dis ") with %%c <Yes/No> : ")))
     (cond
   ((member inp '("Yes" nil ""))(setq dimtext (strcat "%%c" dis)))
   (t (setq dimtext dis)))
     (command "dim1" "al" pt1 pt3 pause dimtext)
give it a go...
gr. Rlx
     (Initget "Yes No")
     (setq inp
        (getkword
     (cond
give it a go...
gr. Rlx
Many thanks !;)
This is I need.
(setq e1 (entlast))
(setq obj (vlax-ename->vla-object e1))
(vla-put-extline2suppress obj :vlax-true)
(vla-put-DimLine2Suppress obj :vlax-true)
That last part wasn't in the job description so I assumed you had made a specific dimstyle :-)
gr. Rlx
Hi dude, This is a specific dimension , SO, no need a new dimstyle
why need use "setvar" ? Can replace?
The setvar is used to get the perpendicular point on the centerline so from there I can calculate the 'mirror' point , the other point for your dimension. But don't worry , this var is replaced automaticly with every (last) point you click. This way it should work at all angles (haven't tested it)
gr. Rlx
