Deleting selected texts on the list - Help
pavilon
I have a dcl and a lisp that list all text and mtext in a drawing and I want to delete selected texts on the list by Delete button on DCL but I need to resolve(if possible):
1) My first goal to delete multiple texts by selection does not work! I get an error of : error: bad argument type: consp nil
2) Overwriting duplicated texts or group similar texts
3) Sorting out text from A_Z , 0-9, etc.
4) how can stay in dialogue until I finish erasing desired texts? Now it closing dialogue(although delete not working properly)
attached is my lisp and dcl.
Thanks
deltext.dcl
DELTEXT.LSP
I have not read your lisp file (yet) , things 2 do you know, but as for point 3 in your wishlist , I think you need to hide your dialog because erasing texts mean updating your display and that is forbidden when a dialog is active.
Gr. Rlx
Just had a quick look during my break and your code stops at (nth item t_lst) because t_lst is nil.
Do you mean (nth item l) instead of t_lst ? ... as in (setq l (_list_texts))
gr.Rlx
Edited by rlx
Ok , my boss is gonna kill me for not having this drawings ready yet ;-) but try this :
(vl-load-com)
;scan for string
(defun sfs ( %p1 %p2 / ss i enum etyp elist)
  (if (setq elist '() i 0 ss (ssget "c" %p1 %p2))
      (while (setq enum (ssname ss i))
          (setq etyp (cdr (assoc 0 (entget enum))))
          (if (member etyp '("TEXT" "MTEXT"))(setq elist (append elist (list enum))))
          (setq i (1+ i))))
   elist
(defun rdup ( i / o );remove duplicates
   (vl-remove-if '(lambda (x) (cond ((vl-position x o) t) ((setq o (cons x o)) nil))) i))
(defun rlx_deltxt ( / txt-ent-list stringlist ent)
   (setq txt-ent-list (sfs (getvar "extmin") (getvar "exmax")))
   (setq stringlist (rdup retlist))
   (foreach ent txt-ent-list
    (if (member (vla-get-textstring ent) stringlist) (entdel ent))))
your retlist can contain duplicates so i remove them first.
with sfs (scan for string) i scan the entire dwg for text / mtext
finaly i test each (m)text entity if it contains one of the selected strings and if it does it will be deleted.
I haven't tested it yet
gr. Rlx
Edited by rlx
(if (= (start_dialog) 1)
(do_atn)
(unload_dialog dcl_id)
(princ "\nTexts Deleted ..:\n")
(princ  retlist)
BTW , add just add my code to your lsp and replace (do_atn) at the end of your code with (rlx_deltxt)
gr. Rlx
