Results 1 to 6 of 6
    Super Member bjenk8100's Avatar
    bjenk8100's Computer Details
    windows 8 64 bit
    Construction
    AutoCAD 2018
    Sep 2009
    622
    Default points to contours
    Hello,
    I am using autocad 2014, not Civil 3D! My goal is to make contour lines from points in both 2D/3D. As of now, I am able to set my workspace in ACAD to 3D. I copy my point values from excel, then click draw>point, then paste point coordinates on command line. Success! All my points are pasted in correct locations. Now, from here is there any automatic way to make contours. I know I could draw splines but I would rather not. I would also like more contour lines in between. I know civil 3D does this easily. Only thing I have seen is using a plugin. If there is no easy way of doing this in autocad arch 2014 does anyone know of anything for free that can help me achieve this.
    Tnx
    Junior Member hlammerts's Avatar
    AutoCAD 2014
    Sep 2014
    22
    You need a tiangulation tool. Maybe this threat on the swamp may help?
    http://www.theswamp.org/index.php?to...0459#msg550459
    windows 8 64 bit
    Construction
    AutoCAD 2018
    Sep 2009
    622
    that thread did not really help. Thanks anyway
    Forum Deity Organic's Avatar
    Civil
    AutoCAD not applicable
    Feb 2009
    2,338
  5. #5
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,015
    Also YMG3 has posted some contour routines here.
  6. #6
    Full Member
    AutoCAD 2013
    Jul 2015
    70
    I believe this will do your work very nice
    https://apps.autodesk.com/ACD/en/Det...ckprofile%3aen
  1. contours from points
    By Kwiz in forum AutoCAD Beginners' Area
    Last Post: 21st Feb 2014, 02:19 am
  2. Please help with making contours from points
    By skills12345 in forum Civil 3D & LDD
    Last Post: 8th Aug 2013, 10:52 am
  3. Create Contours Froms Points
    By joan in forum Civil 3D & LDD
    Last Post: 27th Apr 2010, 10:32 am
  4. Contours
    By waqashraf in forum AutoCAD Beginners' Area
    Last Post: 17th May 2009, 05:11 am
  5. contours
    By sharma in forum AutoCAD General
    Last Post: 3rd Feb 2005, 09:31 pm
