Page 1 of 2 1 2 LastLast
Results 1 to 10 of 20
    Junior Member
    AutoCAD 2010
    Aug 2009
    14
    Default Help with Polyline Lisp (Export All Lengths to Table)
    Hello, I am searching for a lisp that can export the lengths of all selected polylines and export them to either Excel or an AutoCad table.
    I have found and tested around 20 lisps but so far cannot find the right one.
    There were only 2 that look promising, maybe they could be modified?
    One was by Lee Mac and the other Jimmy Bergmark. I can post the 2 Lisp if needed.
    The lisp would need to have you select multiple polylines and give the total lengths of each polyline in the order that they were selected in. Then the data would either appear on an AutoCad table or Excel.
    Thanks for any help that can be provided.
    Super Member Commandobill's Avatar
    AutoCAD 2014
    Oct 2008
    Raleigh, NC
    538
    The lengths of each individual polyline or the total length?
    ***Commandobill***
    Abusing AutoCad Since 1999
    "Caddatude... Do you has it?"
    Sorry for my poor English, I'm American...
    Junior Member
    AutoCAD 2010
    Aug 2009
    14
    Quote Originally Posted by Commandobill View Post
    The lengths of each individual polyline.
    Total is really not needed or can be added at the end of the table or excel if it is not to much trouble.
    Luminous Being Tharwat's Avatar
    Mechanical
    Tharwat's Discipline Details
    MEP AutoCAD Draughtsman
    Mechanical
    HVAC, Drainage, Water Supply, Fire Fighting and a little about Electricity.
    AutoCAD 2017
    Oct 2009
    Great Syria , Living in Abu Dhabi
    6,246
    Try this program to export LWpolylines to Excel file with format csv.
    Code:
    (defun c:Test (/ s f o)
      ;; Tharwat 26. 08. 2015 ;
      (princ "\nSelect LWpolylines to export to Excel file :")
      (if (and (setq s (ssget '((0 . "LWPOLYLINE"))))
               (setq f (getfiled "Specify File Name" (getvar 'DWGPREFIX) "csv" 1))
               (setq o (open f "w"))
          ((lambda (r / e)
             (while (setq e (ssname s (setq r (1+ r))))
               (write-line (rtos (vlax-curve-getdistatparam e (vlax-curve-getendparam e)) 2 4) o)
            -1)
          (close o)
    Junior Member
    AutoCAD 2010
    Aug 2009
    14
    Quote Originally Posted by Tharwat View Post
    Looks good so far. I do have a few tweaks if possible.
    Is there a way to have the values show up in feet only?
    Is there a also a way to have it load up excel without having to save location first and then open?
  6. #6
    Mechanical
    Mechanical
    AutoCAD 2017
    Oct 2009
    6,246
    Quote Originally Posted by gordon_Gjs View Post
    Add the complete path of the Excel file and be aware that each time you run the program , the new data would replace the old once .
    Code:
               (setq f "C:\\New Folder\\Example.csv") ;; path of Excel path
          ((lambda (r / e)
              (write-line (rtos (cvunit (vlax-curve-getdistatparam e (vlax-curve-getendparam e)) "mm" "feet") 2 4) o)
            -1)
          (close o)
  7. #7
    Junior Member
    AutoCAD 2010
    Aug 2009
    14
    I could only get it to save to my thumb drive. It would not save to the local drive C:. Any idea of why this would be? Maybe trust issues? Does it have to save at all or can it just open excel?
    Also, could you have the values show up in feet?
    Thanks for all your help!
  8. #8
    Mechanical
    Mechanical
    AutoCAD 2017
    Oct 2009
    6,246
    Yeah , it might be a matte of security issue , anyway right click on the folder that you wan to safe the excel file in , then go to properties then from the show up dialog go to security tab and edit the group / user name to have a full access.
    If the program did not change the value to feet format from the latest posted program , and replace the number 3 to 4 and try again.
  9. #9
    Junior Member
    AutoCAD 2010
    Aug 2009
    14
    It is still not showing up in feet. Do you have any other ideas to get it to feet?
  10. #10
    Mechanical
    Mechanical
    AutoCAD 2017
    Oct 2009
    6,246
    I updated the codes above , try it and let me know .
  1. Pline lengths organized in a table
    By Caderious Jackson in forum AutoCAD LT
    Last Post: 12th Mar 2015, 01:47 pm
  2. Export table to PDF using lisp
    By rodrigo_sjc_sp in forum AutoLISP, Visual LISP & DCL
    Last Post: 28th Jan 2014, 03:53 pm
  3. Export table using lisp, keeping style, and block cells
    Last Post: 22nd Jan 2014, 10:21 pm
  4. lisp to export the handles and the x, y coordinates for a polyline
    By tiny_21_2003 in forum AutoLISP, Visual LISP & DCL
    Last Post: 12th Jul 2013, 02:38 pm
  5. Polyline lengths
    By happyunited in forum AutoCAD Drawing Management & Output
    Last Post: 23rd Jan 2007, 11:06 am
Tags for this Thread
