jessiray8 Posted August 28, 2015 Share Posted August 28, 2015 (edited) Good day sons of tron, I am needing assistance in the matrix to help our team win the LRT bid. Our engineering did not provide prop road and track surfaces so i have to develop something quick based on a variety of cross sections. I am an experienced CAD operator but i am still learning C3D. I have: existing contours prop alignment with 3d polyline prop pdf cross sections I was thinking the fastest way is to somehow use a sweep surface in C3D from quick poly-line cross sections and convert to a surface to compare from but i am not able to add the sweep surface to a surface, I thought that create sub assembly from a poly-line would work this way, but I could not get it too work. Sons of tron, can you assist your brother-en. http://img4.wikia.nocookie.net/__cb20131112021223/disney/images/0/09/2010_tron_evolution-wide-1-.jpg Edited August 29, 2015 by jessiray8 Quote Link to comment Share on other sites More sharing options...
jessiray8 Posted August 28, 2015 Author Share Posted August 28, 2015 (edited) hello, what is the best way to do a cut fill volume for LRT and Prop road. I have: Prop Alignment with 3d polyline Existing ground PDF cross sections I tried: Sub assembly from 2d polyline Convert sweep surface into a surface Edited August 29, 2015 by jessiray8 Quote Link to comment Share on other sites More sharing options...
