Ibanezboy21 Posted August 31, 2015 Share Posted August 31, 2015 Hi everyone I'm trying to create a dynamic block for my doors and I cannot figure out why my attributes wont show up when I use 'test block' I could see the number change as I stretch my door but when I insert them in my plans, the number wont show up at all Any ideas? refer to attachment (block is shown highlighted in purple) TEST.dwg Quote Link to comment Share on other sites More sharing options...
steven-g Posted August 31, 2015 Share Posted August 31, 2015 Run the attsync command, and select the block when prompted. Any new blocks you insert should work as expected, but if you add an attribute to a block, you should use attsync to update existing blocks. Quote Link to comment Share on other sites More sharing options...
Ibanezboy21 Posted September 1, 2015 Author Share Posted September 1, 2015 wow thank you, do I have to use this command everytime I open up the block? Quote Link to comment Share on other sites More sharing options...
steven-g Posted September 1, 2015 Share Posted September 1, 2015 No, usually only when you add an attribute to an existing block, Quote Link to comment Share on other sites More sharing options...
Ibanezboy21 Posted September 1, 2015 Author Share Posted September 1, 2015 oic thanks, ok last question is there a way to fix my door so the attribute will always be centered with my door? when i increase the width, the attribute will always be centered but if i flip the door and decrease the door size, the attribute wont be centered anymore sorry about the questions, currently learning off youtube and i cannot figure this one out Quote Link to comment Share on other sites More sharing options...
steven-g Posted September 1, 2015 Share Posted September 1, 2015 Usually the best way to handle attributes, when you need to move them is to use a point parameter. You link the attribute to the point parameter with a move action, and then any other actions are performed on the point parameter itself by any other actions, it's a bit difficult to explain, give it a try and see how it works out, I should get a chance later today to try and adapt your block, to show you what I mean (if you don't manage it before then). Quote Link to comment Share on other sites More sharing options...
steven-g Posted September 1, 2015 Share Posted September 1, 2015 OK I managed to take a look. Ignore the point parameter I mentioned before, I changed the attribute text justification to "center-middle" and moved the attribute to line up with the center of the door, and made an adjustment to how the move actions where associated with the flip actions. It looks like it works but try it and see. TEST2.dwg Quote Link to comment Share on other sites More sharing options...
Ibanezboy21 Posted September 2, 2015 Author Share Posted September 2, 2015 oh that's smart, thank you so much! I'm hoping to make a few more in the future and this will be my template. Quote Link to comment Share on other sites More sharing options...
Ibanezboy21 Posted September 5, 2015 Author Share Posted September 5, 2015 Steven im trying to add a rotation action to my attribute but i cant get the rotation basepoint to stay with the text whenever i flip the door left/right and inside out. do you know a good way to fix this? been googling and youtubing and there's no tutorials on it Quote Link to comment Share on other sites More sharing options...
steven-g Posted September 7, 2015 Share Posted September 7, 2015 Dynamic blocks are fairly straight forward, when you keep them simple, but once you start trying to add various different types of patrameters the rules become unclear, especially when it comes to "chaining" actions. Sometimes you need to include the parameter other times you need to include only the action. I usually end up just trying various combinations, testing them and seeing what happens. The good news is, that most things are possible, it just sometimes takes a lot of work. Is it just the attribute text you want to rotate? if so what are the logical rules it needs to follow. Or is it the whole block Quote Link to comment Share on other sites More sharing options...
Ibanezboy21 Posted September 9, 2015 Author Share Posted September 9, 2015 i just need the '000' to rotate, best solution i can come up with is have a similar parameter to my left/right flip action (everytime the door stretches 100mm, the arrow moves in increments of 50mm so the arrow will always be centered to the door) if i add another linear dimesion to the door panel (one going vertical), is there a way to make the basepoint of my attritube center to that? Quote Link to comment Share on other sites More sharing options...
steven-g Posted September 9, 2015 Share Posted September 9, 2015 Could you show on a drawing, where you are trying to get the attribute to be when it rotates, and preferably for a door of 620 and again a door of 1020. And show the second dimension? Quote Link to comment Share on other sites More sharing options...
