manderson Posted September 3, 2015 Share Posted September 3, 2015 I have a drawing that I cannot see or select the viewport. I can't figure out how to make it visible and all of the settings in the layer manager are on/thawed. Any suggestions on how to make the viewport visible would be great. Thanks! Quote Link to comment Share on other sites More sharing options...
ReMark Posted September 3, 2015 Share Posted September 3, 2015 (edited) If you cannot see it and you cannot select it how do you know it is there? We're talking about a paper space viewport right? Could this invisible viewport be sitting behind your AutoCAD window? Edited September 3, 2015 by ReMark Quote Link to comment Share on other sites More sharing options...
manderson Posted September 3, 2015 Author Share Posted September 3, 2015 Yes, we are talking about a paper space viewport. When you double click in the area where the viewport should be it acts like a regular visible viewport but there is no outline of a viewport there. We can move the background around and if we move it out of the viewport area it disappears. Quote Link to comment Share on other sites More sharing options...
ReMark Posted September 3, 2015 Share Posted September 3, 2015 You didn't happen to get this drawing from someone outside of your company who might be using an AutoCAD vertical product did you? Quote Link to comment Share on other sites More sharing options...
Dana W Posted September 3, 2015 Share Posted September 3, 2015 While in paperspace, cross the viewport frame with a right to left selection window. Open Properties. See if the viewport is one of the items in the dropdown list of selected items. If so, see what sort of unusual properties it has, like color, layer, clipped... Anything that looks out of the ordinary. It may provide some clues. Quote Link to comment Share on other sites More sharing options...
RobDraw Posted September 3, 2015 Share Posted September 3, 2015 In your layer manager check to make sure it is not VPort frozen. Yes, paperspace is considered a viewport by the layer manager. Quote Link to comment Share on other sites More sharing options...
steven-g Posted September 3, 2015 Share Posted September 3, 2015 I can recreate the problem but haven't found a solution yet. If you draw a rectangle in paperspace and use the "mview" command with the option "object" pick the rectangle and then delete the original rectangle, the viewport remains but it is invisible, you can double click inside it to activate it but it remains otherwise elusive. Quote Link to comment Share on other sites More sharing options...
Dadgad Posted September 3, 2015 Share Posted September 3, 2015 I can recreate the problem but haven't found a solution yet. If you draw a rectangle in paperspace and use the "mview" command with the option "object" pick the rectangle and then delete the original rectangle, the viewport remains but it is invisible, you can double click inside it to activate it but it remains otherwise elusive. That is exactly what I suspected had happened, but I am incredibly busy, as I have been all week, glad you got here first! Wouldn't hurt to try the OOPS command, in case it was the last thing deleted. Quote Link to comment Share on other sites More sharing options...
RobDraw Posted September 3, 2015 Share Posted September 3, 2015 I have seen that before. If the OP does not verify a solution, I'll try fooling around with the clipped viewport a little while. I think we came up with a solution for that one. Quote Link to comment Share on other sites More sharing options...
rkent Posted September 3, 2015 Share Posted September 3, 2015 This is usually attributed to the drawing coming from microstation \ Bentley product. Create a new layout and viewport and delete the old layout. Quote Link to comment Share on other sites More sharing options...
Dadgad Posted September 3, 2015 Share Posted September 3, 2015 I have seen that before. If the OP does not verify a solution, I'll try fooling around with the clipped viewport a little while. I think we came up with a solution for that one. I spent a couple minutes trying to recreate the problem using a rectangular object to convert to a viewport, but couldn't erase the rectangle, and leave the viewport. Maybe you will have better luck with the CLIPPED viewport. Sounds like steven made it fail though. Was it an oval shape that I have seen do that before? I even tried using the CHANGE SPACE command on the defining rectangle, but couldn't wrangle it away from the respective viewport. Quote Link to comment Share on other sites More sharing options...
RobDraw Posted September 3, 2015 Share Posted September 3, 2015 I spent a couple minutes trying to recreate the problem using a rectangular object to convert to a viewport, but couldn't erase the rectangle, and leave the viewport.Maybe you will have better luck with the CLIPPED viewport. Sounds like steven made it fail though. Was it an oval shape that I have seen do that before? I even tried using the CHANGE SPACE command on the defining rectangle, but couldn't wrangle it away from the respective viewport. I couldn't get the viewport to remain, either. Quote Link to comment Share on other sites More sharing options...
ReMark Posted September 3, 2015 Share Posted September 3, 2015 manderson: Please attach a copy of the actual drawing file itself (not an image) to your next post so we can witness this anomaly ourselves then perhaps a solution will be forthcoming. Quote Link to comment Share on other sites More sharing options...
steven-g Posted September 4, 2015 Share Posted September 4, 2015 For those of you who can't see the issue, here is a layout with an invisible / unselectable viewport. PS this may or maybe not be, the same issue as the OP has. invisible.dwg Quote Link to comment Share on other sites More sharing options...
Dadgad Posted September 4, 2015 Share Posted September 4, 2015 For those of you who can't see the issue, here is a layout with an invisible / unselectable viewport.PS this may or maybe not be, the same issue as the OP has. Yep, that is pretty odd. Thanks for posting that steven-g. Quote Link to comment Share on other sites More sharing options...
RobDraw Posted September 4, 2015 Share Posted September 4, 2015 Yeah, thanks steven. The viewport is selectable in your example using Ctrl+A and it does show as being clipped in the properties. The grips do appear, though. I thought there might be a way to regenerate the boundary or delete the clipping. There isn't, but the viewport can be reclipped. Yielding a selectable viewport. Quote Link to comment Share on other sites More sharing options...
