ElianaCR Posted September 10, 2015 Share Posted September 10, 2015 Hello, I converted step file in ipt , but I can't convert the ipt model in sheet metal. I followed the procedure about set the thickness, but Inventor don't do it, Inventor cant convert to flat pattern...I don't know what is the problem....Somebody can help me , please?.... I Got this step file from a customer... it seem that he set the inside bend radius =0, and bend radius outside was set equal to thickness, I don't know if the problem is because of this.... I am working with Inventor 2011. Quote Link to comment Share on other sites More sharing options...
Lazer Posted September 11, 2015 Share Posted September 11, 2015 Welcome to the forum, It will only work if the if the thickness this consistent, Inventor 2016 introduced bend radius 0 for the first time but don't let that fool you, you can still unfold a step file model with a 0 internal radius in 2011 post the file and I will have a look. Quote Link to comment Share on other sites More sharing options...
