Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
    Forum Newbie
    AutoCAD 2009
    Sep 2015
    5
    Default Problem using variable within Script (.scr)
    Hi, this is my first post on the forum & I'm also pretty new to AutoCAD scripts & Lisp routines, so please bear with me.
    Basically I have the following script:
    (setq dn (strcat (getvar "dwgprefix") "New Drawing.dwg"))
    (vl-propagate 'dn)
    _.saveas 2010 !dn
    This script saves my current drawing as 'New Drawing.dwg' within my current directory, and works fine.
    When I try to modify the script to the following, which attempts to open instead instead of save, it doesn't work, just prompts for drawing name: -
    (vl-propagate 'dn)
    _.open !dn
    The saveas & open dialogues look very similar, so please could someone explain why I can reference a variable for the _.saveas filename, but not for the _.open filename, or have I got the syntax completely wrong for the _.open command?
    Super Member rlx's Avatar
    rlx's Computer Details
    W10
    i74ghz/ssd500/2tbhdd
    Electrical
    rlx's Discipline Details
    electrical designer dragon
    Electrical
    I dont excel in anything but I rearly give up
    AutoCAD 2016
    Nov 2014
    Bergen op Zoom , Netherlands
    1,057
    you could try (setvar "filedia" 0) before the open command (disable file dialog's ) just put it back on (setvar "filedia" 1) when your finished (just good housekeeping)
    gr.Rlx
    Forum Newbie
    AutoCAD 2009
    Sep 2015
    5
    Quote Originally Posted by rlx View Post
    gr.Rlx
    rlx, many thanks for your reply, but no joy, I still just get the prompt 'Enter name of drawing to open' when I run the amended script (below): -
    (vl-propagate 'dn)
    _.open !dn
    Any other ideas?
    Senior Member jonathann3891's Avatar
    jonathann3891's Computer Details
    Window 7 64 Bit
    Structural
    jonathann3891's Discipline Details
    Oil & Gas
    Structural
    AutoCAD 2012
    Dec 2008
    Houston, TX
    126
    This lisp will fail if the drawing your running the script from is not saved in the same directory as "New Drawing"
  5. #5
    W10
    Electrical
    Electrical
    AutoCAD 2016
    Nov 2014
    1,057
    I've written a batch generator for plotting and scripts and there I use the following
    Code:
          (write-line "._Open" fp)
          ;indien van toepassing 'do U wish 2 save changes?'
          (setq cmd "(if (> (getvar \"dbmod\") 0)(command\"yes\"))")
          (write-line  cmd fp)
          (write-line (strcat "(command \""  item "\"))") fp)
          ;indien de te openen tekening read-only is extra enter
          (setq cmd "(while (wcmatch (getvar \"cmdnames\") \"*OPEN*\")(command \"\"))")
          (write-line cmd fp)
    I have an example for the scriptfile itself at work so i'll post that tomorrow
    simply put , when you open a file , if the current drawing needs saving , autocad will ask , do you want to save the current drawing before i open the next dring. Your script has to be prepared for that and add an extra yes or no before it can open the next drawing.
    gr.Rlx
  6. #6
    Forum Newbie
    AutoCAD 2009
    Sep 2015
    5
    Quote Originally Posted by jonathann3891 View Post
    The open/current drawing at the time I run the script is saved in the same directory as "New Drawing".
    I would expect an error if I tried to run the script from a drawing in a different location, as 'dwgprefix' would report this different location.
  7. #7
    Forum Newbie
    AutoCAD 2009
    Sep 2015
    5
    Code:
          (write-line  cmd fp)
          (write-line cmd fp)
    gr.Rlx
    Thanks rlx, but I have tried on a drawing without any changes (no save required), and have also tried adding the double space after the open command to accept any prompts automatically, so the script does not stall as you suggested.
    I can't get my head around why '_.saveas 2010 !dn ' works fine, but '_.open !dn ' doesn't?
  8. #8
    W10
    Electrical
    Electrical
    AutoCAD 2016
    Nov 2014
    1,057
    I've started my batch programm ages ago and still i dont feel like i'm in control so dont feel bad ;-). Maybe you could give some more info about what exactly you try to achieve. Awell , for now i'll finish my wine and go to bed and i'll be back with you 2morrow
    gr.Rlx
  9. #9
    W10
    Electrical
    Electrical
    AutoCAD 2016
    Nov 2014
    1,057
    here is a random part form a script that was generated to plot sa bunch of drawings
    Code:
    ._Open
    (if (> (getvar "dbmod") 0)(command"yes"))
    (command "e:/project/010626_lxv/0400/output lg/04ldk000403cs0001.dwg"))
    (while (wcmatch (getvar "cmdnames") "*OPEN*")(command ""))
    (load "RlPrint")
    rlprint
    \\spboz003\PBOZ0012
    A4 (210 x 297 mm)
    BlackSmall.ctb
    ._Open
    (command "e:/project/010626_lxv/0400/output lg/04ldk000403ds0001.dwg"))
    (load "RlPrint")
    rlprint
    \\spboz003\PBOZ0012
    A4 (210 x 297 mm)
    BlackSmall.ctb
    ._Open
    etc
    it opens a drawing , if current drawing needs saving it gives an axtra "yes". Next it gives the filename of the next drawing to be opened. It can happen that a drawing is read-only so while the open command is active it gives a return. Then it loads and runsmy print routine. The drawing is not saved when done plotting so i directly move on to open the nex drawing.
    This all works fine when sdi=1. if it is zero i use a different approach.
    When your script doesn't work , can you see at what point it stops? If you use vl-propagate you assume vl-load is loaded at all times. Is this true? you also assume setvar 'texteval' is on. You could try (eval dn)
    Just some thoughts from a simple dragon :-)
    well , back to work for me. Hope this helps or another user has some tips to help you on your way.
    gr. R.
  10. #10
    Forum Newbie
    AutoCAD 2009
    Sep 2015
    5
    rlx, you are a star!
    By setting 'texteval' to '1', and adding an extra space after the variable '!dn' with the open command, the script works correctly.
    After a bit of testing, I can confirm it was definitely the 'texteval' being set to '0' (default?) instead of '1', that was causing me issues.
    Many thanks for your help, much appreciated!
    Regards
    Ashley
  1. Problem with variable restoration
    By woodman78 in forum AutoLISP, Visual LISP & DCL
    Last Post: 13th Jun 2015, 03:44 pm
  2. Need quick help adding variable to script startup! THX
    By tmelancon in forum AutoLISP, Visual LISP & DCL
    Last Post: 17th Jan 2014, 01:34 pm
  3. Calling a variable from a Script?
    By DEG in forum The CUI, Hatches, Linetypes, Scripts & Macros
    Last Post: 8th Dec 2012, 10:11 pm
  4. pls help...how to use variable in script
    By nids_1978 in forum AutoLISP, Visual LISP & DCL
    Last Post: 7th Jun 2010, 12:35 pm
  5. Variable in Script
    By Freerefill in forum AutoLISP, Visual LISP & DCL
    Last Post: 18th Sep 2009, 01:09 pm
Tags for this Thread
