toxicsquall Posted September 14, 2015 Share Posted September 14, 2015 I'm trying to plot one of my drawings to grayscale or monochrome style, but my lines and 3d polylines are colored with a color from a color book. When I try to plot, it will plot with the real color, even if I chose the Monochrome or Grayscale plot style. What can I do? (╥﹏╥) Quote Link to comment Share on other sites More sharing options...
CADMASTER1128 Posted September 14, 2015 Share Posted September 14, 2015 (edited) Are the colors you choose TrueColors? I read somewhere that TrueColors always print in color. I also think it makes a difference if you use a .CTB and .STB pen style file. See if the link below helps you: http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Plotting-True-Color-objects-in-monochrome.html Edited September 14, 2015 by CADMASTER1128 Added link for OP Quote Link to comment Share on other sites More sharing options...
rkent Posted September 14, 2015 Share Posted September 14, 2015 Change the colors back to the index colors or convert the file to an .STB file. But unless you already know about .stb files I would just change the colors. Or maybe there is a setting on the plotter to only plot b/w. Quote Link to comment Share on other sites More sharing options...
toxicsquall Posted September 15, 2015 Author Share Posted September 15, 2015 I did this and worked in one of my files, but in another it doesnt. To plot True Color objects in black and white, you will have to convert the plot style table from CTB format (Color Dependant Plot Style Table) to STB format (Named Plot Style Table) and then configure the DWG file to use this STB file instead of the CTB file. To convert your CTB file to an STB file On the command line, enter convertctb In the Select File dialog box, select the CTB file that you want to convert and then click Open. In the Create File dialog box, enter a name for the new STB file and then click Save. To configure your DWG file to use the STB file On the command line, enter convertpstyles Click OK. In the Select File dialog box, select the STB file that you have created and then click Open. When I attempt to plot but the list of plot styles doesnt show the STB files. What can I do? Quote Link to comment Share on other sites More sharing options...
rkent Posted September 15, 2015 Share Posted September 15, 2015 I did this and worked in one of my files, but in another it doesnt. When I attempt to plot but the list of plot styles doesnt show the STB files. What can I do? You only use CONVERTCTB once (it doesn't matter what file you are in as long as it is a CTB file), this will create the STB. Now every drawing that is already set to use CTB has to be converted with CONVERTPSTYLES and then you point to the new STB file. The newly created STB will have R14 color mapping in it (required when using CONVERTPSTYLES) where the ones that come with AutoCAD won't have that. Now point to another STB that doesn't have the R14 color mapping, you will be able to edit that one and add plot styles, etc. Any layer, object, etc. set to a named plot style of Normal will plot in the color it is set to, so move any of those items to a named plot style set to plot B&W. Quote Link to comment Share on other sites More sharing options...
Ski_Me Posted September 16, 2015 Share Posted September 16, 2015 Replace all the ink wells in the printer with black ink. In the long run cheaper and faster than all the man hours your gonna waste trying to figure this out. Sigh, if only it really was this simple. Quote Link to comment Share on other sites More sharing options...
