Change color of text on an attributed block
Efeezy
I am working on a project with Attributed blocks. I need to change the text color of all the blocks I am working with. So all of the blocks will be faded back to 253 on this page then on the next page other blocks will be faded back to show the scope of work. Does anyone have a Lisp that can solve this problem?
What do you mean by page in your post ? A layout?
Can you explain in more details a little bit?
Hi Efeezy,
Have a look at my VT tool. Once you loaded it , press 'tab' at the command line of the routine , select all the attributes and text's you want , press enter so you get to the modify properties dialog , change the color et voila as the germans say...
gr. Rlx
