prime333 Posted September 20, 2015 Share Posted September 20, 2015 Hello everyone. I'm doing an exercise I'm wondering if I could get help doing the top portion of the 3D object. I'm having problems with the two curves on the side how would I do that? Thank you. Quote Link to comment Share on other sites More sharing options...
ReMark Posted September 20, 2015 Share Posted September 20, 2015 Fillet and Chamfer are two commands you might find useful. Their use in 3D is a bit different than in 2D so I would practice each first perhaps on a copy of your model. Quote Link to comment Share on other sites More sharing options...
paaray Posted September 24, 2015 Share Posted September 24, 2015 (edited) Create the complete outline in 2D. Use the fillet command to create the rounds. Use the PEDIT Command to join all the entities and then use the extruded command to extrude. You can then position it on the main block and join. Edited September 26, 2015 by paaray Quote Link to comment Share on other sites More sharing options...
