peterg Posted September 23, 2015 Share Posted September 23, 2015 How can I turn off the dialogue box that appears when ever I select a line in AutoCAD 2010??? Quote Link to comment Share on other sites More sharing options...
Squirltech Posted September 23, 2015 Share Posted September 23, 2015 I think you're referring to the Quick Properties dialog. Type QPMODE in the command line and then enter zero (0), hit enter. Quote Link to comment Share on other sites More sharing options...
Dana W Posted September 23, 2015 Share Posted September 23, 2015 It may be selection cycling. Set the system variable SELECTIONCYCLING to zero (0). Or you can simply ignore it. Once you shift the cursor a bit, it goes away and lets you have whatever you clicked on. The day will come when you will miss it. How else will you select the line under the line, under the line, under the line, when you really need it? Quote Link to comment Share on other sites More sharing options...
tombu Posted September 24, 2015 Share Posted September 24, 2015 I never use SelectionCycling and rarely use quick properties. From my acaddoc.lsp: (if (/= (getvar 'qpmode) -2)(progn(setvar 'qpmode -2)(princ "\nQPMODE to -2. When toggled on only for selected objects supported in the CUI for display with quick properties."))) (if (> (getvar 'selectioncycling) 0)(progn(setvar 'selectioncycling (- (getvar 'selectioncycling)))(princ "\nTurn \"selectioncycling\" off. SELECTIONCYCLING"))) (princ "\nTo Select Objects Close Together: Hover+Shift+Spacebar to Cycle then pick to select visable object.") (princ) I keep my Properties palettes anchored and auto-hidden to the right, no need for a partial version. I heard that SelectionCycling may be useful when working in 3D, but have not come across a use for it so far while using Civil 3D. Easily toggled from the Hamburger icon should the need ever arise. Quote Link to comment Share on other sites More sharing options...
ReMark Posted September 24, 2015 Share Posted September 24, 2015 Could we be talking about Dynamic Input? Quote Link to comment Share on other sites More sharing options...
tombu Posted September 24, 2015 Share Posted September 24, 2015 Could we be talking about Dynamic Input? To be honest I don't remember which release any of these were added. peterg is using AutoCAD 2010. Quote Link to comment Share on other sites More sharing options...
ReMark Posted September 24, 2015 Share Posted September 24, 2015 (edited) I vaguely recall that Dynamic Input might have been around as far back as 2006. Edited September 24, 2015 by ReMark corrected year Quote Link to comment Share on other sites More sharing options...
rkent Posted September 24, 2015 Share Posted September 24, 2015 I vaguely recall that Dynamic Input might have been around as far back as 2006. You are correct sir, 2006 is when Dynamic Input was introduced. Quote Link to comment Share on other sites More sharing options...
