Results 1 to 4 of 4
    Full Member
    AutoCAD 2010
    Aug 2015
    25
    Default Selecting layers by its name
    Hi,
    I'm searching a lisp that selecting layers by them name. As an example I give some names:
    AAA_BBB_xxx
    AAA_BBB_xxy
    AAA_BBB_xyz
    I need to select all layers that names start as AAA_BBB. The third part of name is changing. In this case I'd like to select only this layers that name has AAA_BBB. How can I do this?
    Thank you for any suggestions in advance.
    Jakub
    Luminous Being Tharwat's Avatar
    Mechanical
    Tharwat's Discipline Details
    MEP AutoCAD Draughtsman
    Mechanical
    HVAC, Drainage, Water Supply, Fire Fighting and a little about Electricity.
    AutoCAD 2017
    Oct 2009
    Great Syria , Living in Abu Dhabi
    6,249
    Try.
    Code:
    (setq sel (ssget "_:L" '((8 . "AAA_BBB*"))))
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,717
    Do you need a lisp ?
    FILTER, select object, edit layer name, AAA_BBB* selects all layers that start with AAA_BBB
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,717
    2nd suggestion pick object then "how many characters to match" for above its 7 then substr and use Tharwats suggestion.
    Code:
    ; bit rough but for testing
    (setq obj (vlax-ename->vla-object (car (entsel))))
    (setq lay (vla-get-layer obj) )
    (alert (strcat "You have picked layer " lay "Enter number of characters next step"))
    (setq num ("Enter number of characters"))
    (setq str (strcat (substr lay 1 num) "*" ))
    (setq sel (ssget "_:L" (list (cons 8 str))))
  1. no dotting of locked layers while selecting?
    By rock1 in forum AutoCAD General
    Last Post: 10th Aug 2015, 03:47 am
  2. Selecting Individual Layers Within XRefs
    By SJC2014 in forum AutoCAD Drawing Management & Output
    Last Post: 16th May 2014, 03:41 pm
  3. Viewing/Selecting Layers
    By jwfilion in forum AutoCAD Beginners' Area
    Last Post: 7th Dec 2010, 09:22 pm
  4. Shortcut for selecting layers
    By krimer in forum AutoCAD Drawing Management & Output
    Last Post: 14th Aug 2007, 06:24 pm
  5. Selecting layers per viewport
    By matramurena in forum AutoCAD Drawing Management & Output
    Last Post: 25th May 2007, 11:57 pm
Tags for this Thread
