Page 1 of 2 1 2 LastLast
Results 1 to 10 of 13
    Forum Newbie
    AutoCAD LT 2012
    Sep 2015
    3
    Default Lingering xref linetypes
    ACAD LT 2012
    I have a problem where I somehow got a ton of xref line types in my template drawing. I must have inserted an object from another drawing into it that carried them. I don't have anything xrefed to the drawing.
    I've tried to delete them, but I get the message that I can't delete anything currently being used or in an xref.
    I've also tried copying with base point into another drawing. I went as far as copying individual items into a new drawing with the result being that the xref line types come into the other drawing.
    Any advice will be appreciated.
    Thanks,
    Yport
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,179
    If you can post the file, that would help a lot. Much more information is needed.
    Best guess on limited info is that the linetypes are assigned to layers and/or objects. Maybe, embedded in a block.
    Drafting is a breeze.
    Forum Newbie
    AutoCAD LT 2012
    Sep 2015
    3
    It gets weirder. I copied a small closed polyline (copy with base point) and pasted it into the acadlt.dwt template that was 67 kb. It blew the file up to 5,518 kb. There are no blocks, just a closed polyline. It brought all the xref line types over with it. That was too big to attach.
    I have attached a screen shot of the drawing, layer dialog box, and the open line type selection box. There are over 200 xref line types that are showing up.
    I don't understand why they come over with a simple cut and paste of a single polyline from one drawing to another.
    The problem is that I have a different drawing template with my title blocks, layouts, dimension styles, text styles, plot set ups, and many blocks that I want built into every drawing. It took a long time to put it together and I don't want to start from scratch.
    I'm also concerned that anything that I send to other professionals will pollute their drawings. It is pretty clear to me that it came to me that way as I don't do xrefs.
    Thank you for responding.
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,179
    Quote Originally Posted by yport View Post
    This is not unheard of. Have you tried purging and auditing before the copy and paste?
  5. #5
    Forum Newbie
    AutoCAD LT 2012
    Sep 2015
    3
    I have audited and purged. It won't let me delete or purge the linetypes.
    I just learned that these are not xref dependent linetypes (I filtered them and they did not show up as xref dependent). It seems that the drawings think these line types exist on these layers that don't appear anywhere to exist. Maybe these are layers from a non-autocad drawing ..... I'm very stumped.
  6. #6
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,179
    They could have been in an XREF that was bound to the drawing at one point. What that does is basically insert the XREF as a block and depending on how it is done, it keeps the XREF designation on all the layer, blocks, and linetypes.
    Have you tried WBlocking instead of copy/paste?
    For more direct help, the file is needed. Could you post it to Drop Box?
  7. #7
    Forum Newbie
    Civil 3D 2014
    Nov 2015
    2
    Has anyone figured out how to solve this. I am in the process creating a new template for our office and this same thing happened to me as well. I have purged/audited/wblocked my drawing and nothing. I searched through all blocks and found nothing in relation to the rouge linetypes. It is literally spreading through all of our drawings.
  8. #8
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2019
    Feb 2010
    Oviedo, Florida
    4,782
    Quote Originally Posted by RHILEMAN View Post
    Search the forum for getting rid of DGN linetypes from microstation.
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
  9. #9
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,179
    There are a number of possible solutions but as stated before, having the file takes out the guess work.
    The linetypes are coming from something in your drawing. You need to figure out where. A process for figuring that out would involve starting with a clean drawing and inserting stuff while keeping an eye on the linetypes to see what they come with.
  10. #10
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    6 Gb
    1 Terrabyte
    Construction
    Construction
    AutoCAD LT 2019
    Feb 2010
    Oviedo, Florida
    4,782
    I mentioned the dgn lines since there has been a lot of traffic about them lately, and the behavior noted sounds similar to having them. It's not necessarily the answer.
  1. Filter XREF Linetypes?
    By Prospectmp in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 7th Sep 2011, 06:25 pm
  2. Xref processes image when mousing over xref manager
    By BenE in forum Civil 3D & LDD
    Last Post: 3rd Aug 2010, 04:58 pm
  3. Bound XREF Linetypes
    By JONTHEPOPE in forum AutoLISP, Visual LISP & DCL
    Last Post: 17th Aug 2009, 07:20 pm
  4. Annotative text in XREF? Xref units mm, parent drawing m
    By spittle in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 3rd Aug 2009, 09:06 am
  5. XREF's and linetypes
    By EMS_0525 in forum AutoCAD Drawing Management & Output
    Last Post: 25th Mar 2009, 03:24 pm
Tags for this Thread
