Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 26
    Senior Member
    AutoCAD 2013
    Dec 2014
    Moldova
    109
    Question stop automatically repeating select comand
    few days ago I tryied some lisp files , after those lisps I got a problem , It automatically repeating _select comand
    "Command: _select
    Select objects: !previousSelection"
    after each comand , it begin to make me nervous , how is it possible to stop it ????
    Super Member rlx's Avatar
    rlx's Computer Details
    W10
    i74ghz/ssd500/2tbhdd
    Electrical
    rlx's Discipline Details
    electrical designer dragon
    Electrical
    I dont excel in anything but I rearly give up
    AutoCAD 2016
    Nov 2014
    Bergen op Zoom , Netherlands
    1,068
    Quote Originally Posted by sergiu_ciuhnenco View Post
    "Command: _select
    Obviously one of these lispfiles has an enter ("") to many in their routine. Disable them all and then load them one by one to see which one produces the problem.
    gr. Rlx
    Senior Member
    AutoCAD 2013
    Dec 2014
    Moldova
    109
    the problem is that I already deleted them , also forgot which one I used..
    I tried to many to remember
    W10
    Electrical
    Electrical
    AutoCAD 2016
    Nov 2014
    1,068
    maybe one of them has done something to your acad.lsp? Very difficult to see from here...
  5. #5
    Senior Member
    AutoCAD 2013
    Dec 2014
    Moldova
    109
    I try to remlace it , I had a aditional copy of it , remplace it , same thing , still repeating " _select comand "
  6. #6
    Senior Member
    AutoCAD 2013
    Dec 2014
    Moldova
    109
    I am not shure but probably I try this lisp
    Code:
    (defun c:dimobj (/ ent Minpt Maxpt cRds)   (if (setq ent (car (entsel "\nSelect Something to Dimension...")))     (progn       (vla-getBoundingBox     (vlax-ename->vla-object ent) 'Minpt 'Maxpt)       (setq cRds (mapcar 'vlax-safearray->list (list Minpt Maxpt)))      (command "_dimlinear"            (polar (cadr cRds) pi (- (caadr cRds) (caar cRds)))            (cadr cRds)           (polar (cadr cRds) (* 0.5 pi) (* 2 (getvar "DIMTXT"))))      (command "_dimlinear"           (cadr cRds)           (polar (cadr cRds) (* 1.5 pi) (- (cadadr cRds) (cadar cRds)))           (polar (cadr cRds) 0.0 (* 2 (getvar "DIMTXT")))))     (princ "\n<!> No Object Selected <!>"))   (princ))
    http://www.cadtutor.net/forum/showthread.php?27634-Auto-dimesioning-polyline/page8
    MSasu post
  7. #7
    W10
    Electrical
    Electrical
    AutoCAD 2016
    Nov 2014
    1,068
    check your startup suite maybe? is there an .mnl loaded with your menu? or a arx file? I cant imagine that there would be a autocad setting to create this kind of behaviour.
    maybe try (getvar "cmdnames") to see what command is active?.. quite strange...
  8. #8
    Senior Member
    AutoCAD 2013
    Dec 2014
    Moldova
    109
    give me "" result
  9. #9
    Senior Member
    AutoCAD 2013
    Dec 2014
    Moldova
    109
    rlx can you see in lisp , that I attached little bit higher , something strange , what can make this work wrong ?
  10. #10
    W10
    Electrical
    Electrical
    AutoCAD 2016
    Nov 2014
    1,068
    give me "" result
    well your lisp routine seems to be ok , maybe your 'personal routine' has something to do whith it , check your mouse sensitivity?
  1. Replies: 3
    Last Post: 31st Jul 2012, 03:47 pm
  2. Repeat an AutoCAD command automatically
    By AutoCAD Tips Blog in forum AutoCAD RSS Feeds
    Last Post: 16th Nov 2011, 03:22 am
  3. Replies: 3
    Last Post: 15th Apr 2010, 12:17 pm
  4. How to stop auto select while modeling
    By object31 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 19th Oct 2009, 10:32 pm
  5. In 3D - how to stop UCS from automatically aligning to adjacent object snap point
    By dvjstyles in forum AutoCAD 3D Modelling & Rendering
    Last Post: 3rd Nov 2008, 05:59 pm
