Page 2 of 2 FirstFirst 1 2
Results 11 to 15 of 15
Thread: Plotting PDFs
  1. #11
    Super Member
    Ski_Me's Computer Details
    DELL (why oh lord must I suffer)
    Electrical
    Ski_Me's Discipline Details
    Fire Alarm tech
    Electrical
    AutoCAD 2018
    Apr 2012
    Edmond. OK
    643
    Quote Originally Posted by Dana W View Post
    Which ***.pc3 file or printer/plotter are you using. Sounds like you may be generating raster (image) pdf's instead of vector.
    I think Dana is right make sure your creating a pdf that bluebeam can use. I don't have any clients that use bluebeam but if the file is sluggish and slow to print it may be the software is choking on the info in the file. Does Lt have an option to export as a pdf instead of going the plot route?
  2. #12
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2019
    Feb 2010
    Oviedo, Florida
    4,782
    Yes, it does, at least 2015/16 does. It also has Batch Plot, and Publish, both of which allow choosing whether to include layer and block information. (They are both actually the Publish command. Batch plot is simply a pretty button for it.
    Maybe it is the block info choking it up. OP should make sure to check that too, and to NOT use straight PLOT to pdf from the layout screen, but to use either batch plot or publish which will use the above mentioned check-off items.
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
  3. #13
    Forum Newbie
    AutoCAD LT 2016
    Sep 2015
    6
    Hi all,
    Thank you for your responses. I've been using the plot command and the DWG to PDF pc3 plotter. I will try exporting as a pdf and let you know how i get on!
    Many thanks
  4. #14
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,179
    I have not used BlueBeam but with the price tag that it has, I would think that it should be able to handle raster, as well as vector, PDFs with ease. I'm actually leaning towards it being a local issue on the part of that particular recipient using BlueBeam.
    Could you please post one of the problem PDFs? If there really is an issue, we might be able to spot what it is. I know at least one person that can test it on Blue Beam.
    Drafting is a breeze.
  5. #15
    Forum Newbie
    AutoCAD LT 2016
    Sep 2015
    6
    Hi all,
    The problem has been solved!!!
    It seems it was an issue when I plotted the DWG to PDF, Bluebeam couldn't handle the file. When i Exported the DWG to PDf and done the usual unticking layer information in the options the file worked fine. I also tried the publish option and the file also worked fine.
    I'm not sure why plotting doesn't work, but i'll definitely be exporting from now on!
    Thank you all for your help!!
  1. Plotting from PDFs
    By Vigilante in forum AutoCAD Drawing Management & Output
    Last Post: 27th Aug 2012, 12:22 pm
  2. plotting to pdfs not working
    By cadclueless in forum AutoCAD Beginners' Area
    Last Post: 28th Sep 2010, 10:22 pm
  3. Plotting PDFs in 2010
    By cmmahp in forum AutoCAD General
    Last Post: 5th Feb 2010, 08:42 pm
  4. plotting to PDFs
    By drahcir in forum AutoCAD Drawing Management & Output
    Last Post: 9th Jan 2007, 10:29 am
  5. Plotting A0 .PDFs
    By Pablo Ferral in forum AutoCAD Drawing Management & Output
    Last Post: 14th Mar 2006, 08:59 am
Tags for this Thread
