Page 2 of 2 FirstFirst 1 2
Results 11 to 14 of 14
  1. #11
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,600
    Do you want in one drawing, rather than multiple ?
    Will try to find time to do something.
  2. #12
    Junior Member
    AutoCAD 2014
    Sep 2015
    15
    In multiple drawings ideally. I really appreciate your help, the majority of this sort of thing is lost on me at the moment
  3. #13
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,600
    Ok this is very first step get the read file working, next will be to write a script and repeat for multiple files. Try it by just changing the file name at end. Thanks also to lee-mac.
    Code:
    ; tunnel takes a txt file ignores lines that are not xy description
    (vl-load-com)
    ;;-------------------=={ Parse Numbers }==--------------------;;
    ;;  Parses a list of numerical values from a supplied string. ;;
    ;;  Author: Lee Mac, Copyright © 2011 - www.lee-mac.com       ;;
    ;;  Arguments:                                                ;;
    ;;  s - String to process                                     ;;
    ;;  Returns:  List of numerical values found in string.       ;;
    (defun LM:ParseNumbers ( s )
        (lambda ( l )
          (read
            (strcat "("
              (vl-list->string
                (mapcar
                  (function
                    (lambda ( a b c )
                      (if
                        (or
                          (< 47 b 58)
                          (and (= 45 b) (< 47 c 58) (not (< 47 a 58)))
                          (and (= 46 b) (< 47 a 58) (< 47 c 58))
                        b 32
                  (cons nil l) l (append (cdr l) (list nil))
        (vl-string->list s)
    (defun tunnel (fname / x xyzlist xyz)
    (setq fo (open fname "R"))
    (command "_pline")
    (while (= (getvar "cmdactive") 1 )
    (while (setq newline (read-line fo))
    (if (or (= (substr newline 1 1 ) "+")(= (substr newline 1 1 ) "-"))
    (setq xyzlist (LM:ParseNumbers newline))
    ;(setq xyz (strcat (rtos (nth 0 xyzlist)2 4) "," (rtos (nth 1 xyzlist)2 4)))
    ;(command xyz) ; co-ords of line
    (command (list (nth 0 xyzlist) (nth 1 xyzlist) 0.0))
    );progn
    (princ "skip")
    );if
    ); while read file
    (command "") ; end line
    ) ; end pline while
    );defun
    ; run code
    (tunnel "C:\\acadtemp\\175475BK.txt")
    ;(command "saveas" "c:\\cadtemp\\175475BK" "close")
  4. #14
    Junior Member
    AutoCAD 2014
    Sep 2015
    15
    When running that .lsp it returns an error:
    first test.lsp successfully loaded.
    Command: _pline
    Specify start point: ; error: bad argument type: FILE nil
    Command:
    Specify start point: *Cancel*
    Command: *Cancel*
    Any ideas?
  1. AutoLisp Error Handling - Command in Custom Error Causes Error
    By RonnieMoore in forum AutoLISP, Visual LISP & DCL
    Last Post: 8th Nov 2013, 05:28 pm
  2. Tutorial: Create a custom command for AutoCAD using AutoLISP
    By AutoCAD Tips Blog in forum AutoCAD RSS Feeds
    Last Post: 16th Jul 2012, 08:50 pm
  3. Custom Command in Command line
    By goonkt in forum The CUI, Hatches, Linetypes, Scripts & Macros
    Last Post: 6th Jul 2012, 06:37 pm
  4. Replies: 6
    Last Post: 15th Nov 2011, 02:27 pm
  5. Autolisp for custom blocks.
    By cadsultant in forum AutoCAD Drawing Management & Output
    Last Post: 8th Apr 2005, 08:24 am
Tags for this Thread
