Results 1 to 4 of 4
    Forum Newbie
    AutoCAD 2007
    Oct 2015
    2
    Default AutoCAD User Documentation File
    Hi,
    Can anyone tell me where can i find the User Documentation file for AutoCAD LT 2007 and AutoCAD LT 2016 versions? The legal team of our company is asking for this file To be used as their reference before they can approved the installation of the said softwares in our company owned PCs. Thank you very much in advance.
    What I exactly need is the User Documentation file referred in this section of the EULA.
    "2.2 License Parameters. Autodesk's license grant is subject to one or more of the License Parameters defined in this Section 2.2 as specified in the User Documentation. Unless Autodeak expressly specifies or agrees otherwise in the User Documentation, all Software shall be governed solely by a license fo Standalone (Individual) Versions (see Section 2.2.1)."
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,638
    All documentation for 2007 should be on the installation media.
    Did you download 2016 or did you actually get an installation DVD?
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2018
    Feb 2010
    Oviedo, Florida
    4,727
    It comes with 2016, or is downloadable from AutoDesk. As far as 2007 goes, Autodesk no longer supports it. The 2007 version can no longer be licensed for a new install. However, you may be able to run it as a personal copy on your own workstation if you personally hold the license. Then again, if it can be installed, you must have the install media. The documentation should be with the program.
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
    Forum Newbie
    AutoCAD 2007
    Oct 2015
    2
    Hi ReMark and Dana,
    Already found them in the installation medias.
    Thank you much for your assistance. Appreciate it.
  1. New AutoCAD AutoLISP Documentation Available
    By Between the Lines in forum AutoCAD RSS Feeds
    Last Post: 30th Oct 2013, 08:50 pm
  2. Drawing file is write protected (DWG was opened by other user) Autocad 2010
    By Sengna in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 4th Oct 2013, 05:42 am
  3. AutoCAD Developer Documentation Survey
    By HyperPics in forum AutoCAD RSS Feeds
    Last Post: 28th Feb 2013, 06:30 pm
  4. AutoCAD 2012 for Mac Documentation
    Last Post: 17th Aug 2011, 06:50 pm
  5. Model Documentation in AutoCAD 2012
    By AutoCAD Insider in forum AutoCAD RSS Feeds
    Last Post: 9th Apr 2011, 03:00 pm
Tags for this Thread
