Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 28
  1. #11
    Senior Member tmelancon's Avatar
    tmelancon's Computer Details
    Windows 7 Professional
    Dell Optiplex 7010
    i3-3220 Processor (Quad Core, 3.30GHz)
    8GB
    HD2500 Graphics
    500GB
    2TB External Backup
    Dual Dell 27" Monitors!!
    Multi-disciplinary
    tmelancon's Discipline Details
    CAD Operations/Design
    Multi-disciplinary
    CAD Design, CAD Management, Project Management, ISO Drawings, Pressure Vessels, Inspection Reports, Data Analysis, Work Scope Recommendations, Troubleshooting, and anything else the boss needs to maximize efficiency. Also proficient in Electrical Engineering/Lighting Design and LEED Green Energy
    AutoCAD 2015
    Jun 2013
    327
    Another example. With that being said, the user would also have to be able to change angle after selecting points, to illustrate a vertical or horizontal angle.
    .Again, if this isnt worth the time Lee I completely understand I was just using Cad Tutor as a resource in case some other piping designers out there (that aren't using Autocad Plant 3D) had something in mind.
    It is better to remain silent and be thought a fool, than to open your mouth and remove all doubt. -Abraham Lincoln
  2. #12
    Lee Mac's Computer Details
    Win 7 Pro / Win 10 Pro / Linux Mint
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,599
    Looking at your results, you will probably need to reduce the triangle offset specified at the top of the code.
    I have added a GIF to my earlier post to demonstrate how the program should operate.
    Lee
    Lee Mac ProgrammingTwitterExchange App StoreDropbox (500MB free)
  3. #13
    Dell Optiplex 7010
    8GB
    HD2500 Graphics
    500GB
    2TB External Backup
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2015
    Jun 2013
    327
    Lee, what are your credentials you entered at the top, that looks pretty close to what I am wanting.. Outstanding!!
  4. #14
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,599
    Quote Originally Posted by tmelancon View Post
    I am running the code as posted - you will need to change the offset & scale to suit the size of your drawings (an offset of 10 units will be much too large if your lines are only 1 unit in length).
  5. #15
    Dell Optiplex 7010
    8GB
    HD2500 Graphics
    500GB
    2TB External Backup
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2015
    Jun 2013
    327
    For some reason when I click the second point on the end point of my line is gives me the error "Cannot generate triangle for isometric angle." However, when I click just shy of that end point it generates the triangle? Any ideas as to why?
  6. #16
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,599
    Yes, the triangle cannot be generated for multiples of 30 degrees, as the baseline of the triangle will run along these isometric lines, however, I realise I should remove 60 degrees etc from this restriction.
  7. #17
    Dell Optiplex 7010
    8GB
    HD2500 Graphics
    500GB
    2TB External Backup
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2015
    Jun 2013
    327
    Sounds good I appreciate your efforts tremendously. We never know what angles are CAD technicians are going to draw these angles at. Now what they are supposed to draw them at and what the draw them at is a different story. LOL. See if you can make it to where there are no restrictions. Thanks LEE!!
  8. #18
    Dell Optiplex 7010
    8GB
    HD2500 Graphics
    500GB
    2TB External Backup
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2015
    Jun 2013
    327
    I wonder if you can make a separate code modified to look like the hatching in my post #11, which is what we call a horizontal hatch for 90s that are rolled but are essentially at exact same elevations. I will call the first one ISOV and the horizontal one ISOH.. Thanks for everything LEE!
  9. #19
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,599
    Thank you for your gratitude.
    Though as explained, lifting all restrictions on the angle is not possible as the baseline of the triangle will follow the isometric axis line (at 30 degrees, for example).
  10. #20
    Dell Optiplex 7010
    8GB
    HD2500 Graphics
    500GB
    2TB External Backup
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2015
    Jun 2013
    327
    In your GIF I see you choosing both end points. When I try and replicate that action, I get the error in result. But in your GIF you clearly are able to perform the routine with two end points of the line at that specific angle. Any thoughts?
  1. creating a custom colour book (AutoCAD 2014)
    By designerstuart in forum AutoLISP, Visual LISP & DCL
    Last Post: 11th Aug 2014, 11:56 am
  2. AutoCAD 2014 'Tangent' ignores ellipses in isometric, but ...
    By Vagulus in forum AutoCAD Bugs, Error Messages & Quirks
    Last Post: 17th Sep 2013, 09:29 am
  3. Replies: 6
    Last Post: 2nd Jul 2013, 02:37 pm
  4. creating hatches
    By bjenk8100 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 22nd Jan 2010, 12:26 am
  5. Creating Hatches
    By Mikiko in forum AutoCAD Beginners' Area
    Last Post: 18th Nov 2009, 08:27 pm
Tags for this Thread
