IronHorse Posted October 3, 2015 Share Posted October 3, 2015 I have noticed one strange thing. When I work with multisolids, I can check individual volymes for each solid. And It produce correct result. I check this in part (.ipt) But If I insert this multisolid in assembly (.iam) double click the part and check volymes for solids. It produce wrong volymes? How come It´s not the same? See attached screencap. Top cylinder is 3m in diameter and 0,75m thick. Correct volyme is approximate 5.3 m³ but when I check in assembly mode It prodúce different value. Quote Link to comment Share on other sites More sharing options...
