Results 1 to 2 of 2
    Super Member bjenk8100's Avatar
    bjenk8100's Computer Details
    windows 8 64 bit
    Construction
    AutoCAD 2018
    Sep 2009
    625
    Default Loft - Ruled vs Smooth
    Just out of curiosity. If you loft 3 different circles. Top (6"), Middle (3") and bottom (6") for example. I go to wire frame view. If i choose loft type rule it shows multiple lines throughout wire frames. Smooth does not. Just don't like the way loft smooth type looks in wireframe. Anyone know a way to get more lines in smooth loft style to show up? I attached two screen shots of what I am talking about.
    Senior Member lrm's Avatar
    lrm's Computer Details
    Windows 7 64-bit
    16 GB
    Education
    lrm's Discipline Details
    Teacher, AEC and mechanical
    Education
    Civil and Mechanical
    3ds Max 2017
    Jan 2010
    Massachusetts, USA
    381
    1. Open the Visual Style Manager dialog box with the visualstyles command.
    2. Drag the 2D Wireframe option into the view.
    3. Change the value of the 2D Wireframe option for Contour lines from the default of 4 to 8 or 16.
    4. Give the REGEN command.
    ~Lee
  1. Loft - Centreline not smooth
    By dodyryda in forum Autodesk Inventor
    Last Post: 13th Nov 2013, 06:33 pm
  2. No smooth edge on loft of propller blade.
    By Edwinh in forum AutoCAD 3D Modelling & Rendering
    Last Post: 6th May 2010, 09:02 pm
  3. Loft: rail curve not smooth
    By Filip Arvidsson in forum Autodesk Inventor
    Last Post: 28th Dec 2009, 05:15 pm
  4. Loft With Ruled Path...is It Possible?
    By DidzisK in forum AutoCAD 3D Modelling & Rendering
    Last Post: 5th Mar 2009, 01:44 pm
  5. Solids with ruled surfaces
    By bierot in forum AutoCAD 3D Modelling & Rendering
    Last Post: 19th Dec 2005, 09:26 am
