Results 1 to 9 of 9
    Forum Newbie
    AutoCAD 2015
    Oct 2015
    3
    Default Is there a way to create a "negative" solid?
    Basically I want to subtract a solid from another solid without actually subtracting it. Not sure if this is possible or if anyone has a different solution, but here's the background: I have a concrete structure with numerous pipe sleeves and blockouts that I would like to subtract out, but they haven't settled on anything yet and they move sometimes daily. I want to be able to keep a group of solids that represent void areas that are easy to move around and appear as voids in my main solids. This would prevent me from having to start from scratch on the voids every time something changes and maintaining a base set of solids. Any suggestions or alternatives are appreciated. Just looking for a more efficient way of model maintenance.
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,736
    I'd put the concrete slab on one layer and the "voids" as you call them on another and assign each a different color. I wouldn't subtract the voids until the final placement is determined. Then I'd use the xray visual style to see where the voids are in relationship to the slab. Move them as many times as you want.
    You are aware though that even if you did subtract them they could be repositioned via the Move Faces command right?
    Luminous Being tzframpton's Avatar
    tzframpton's Computer Details
    HP Zbook
    Multi-disciplinary
    tzframpton's Discipline Details
    BIM Specialist
    Multi-disciplinary
    Full Virtual Design and Construction BIM services for the MEP engineering and construction industries.
    Revit 2018
    Mar 2006
    Dallas, TX - USA
    9,075
    Explore the INTERFERE command. During the command, there's an option before completing the task where it doesn't delete the solid created. It works in the same way as SUBTRACT, but instead of deleting the geometry it creates a new solid in its place, without tampering with the original solid.
    Hope this helps.
    Tannar Z. Frampton ™ | Frampton & Associates, Inc.
    Forum Newbie
    AutoCAD 2015
    Oct 2015
    3
    I figure that's where I'll end up, but not quite what I'm going for. Guess I'm looking for a solid version of a wipeout command, if that makes any sense.
  5. #5
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    16GB, 1600MHz, DDR3 non-ECC 2x8GB
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2017
    Nov 2007
    4,588
    Go ahead and punch the holes in the concrete slab. You can grab them and erase, move, scale the opening. Simply hold the CTRL key down, select on the face of the hole, and erase, or grab the grip and move it around, or use the scale command and go from there.
    Sometimes there's a man... I won't say a hero, 'cause, what's a hero? But sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place. He fits right in there. And that's the Dude, in Los Angeles. - The Stranger, The Big Lebowski
  6. #6
    Forum Newbie
    AutoCAD 2015
    Oct 2015
    3
    Thanks for the quick replies and good advice. I think the move faces and the ctrl select faces will get me by for what I need to do. Still interested if someone knows of some kind of anti-solid/ 3d version of a wipeout.
  7. #7
    Junior Member hlammerts's Avatar
    AutoCAD 2014
    Sep 2014
    22
    AutoCAD architecture has the ability to model with voids for boolean operations.
    Yet, still is still restricted to ACA for many years. I was hoping this would be available for other verticals some day.
    http://docs.autodesk.com/ARCHDESK/20...869FFDE2BC.htm
  8. #8
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,736
    Keep hoping. Maybe it will happen in your lifetime.
  9. #9
    Super Member halam's Avatar
    AutoCAD 2017
    Jul 2015
    671
    Great observation remark.
    Plenty of void when you're dead 😊
  1. Replies: 21
    Last Post: 14th Jul 2014, 07:04 am
  2. Replies: 1
    Last Post: 26th Jan 2012, 11:46 am
  3. Convert "body" to "Solid"
    By powerdog in forum AutoCAD 3D Modelling & Rendering
    Last Post: 12th Jun 2007, 04:11 pm
  4. Creating a negative "image" from an existing drawi
    By tomsnyder in forum AutoCAD General
    Last Post: 10th May 2006, 04:33 am
  5. VBA problem in create a "region" use "addlwpo
    By clarence_cad in forum AutoLISP, Visual LISP & DCL
    Last Post: 30th Sep 2005, 08:19 am
