Results 1 to 2 of 2
    Forum Newbie
    Electrical 2016
    Oct 2015
    2
    Default Revise grid equivalent of revise ladder. Does it exist?
    Hi,
    I create X-Y grids and after I make changes I want them to revise on the grids. Is this possible?
    Thank you.
    Edit: Also, I notice after creating the grids the labels act like text objects rather than 'special' objects.
    Senior Member Kemphas's Avatar
    Electrical
    Kemphas's Discipline Details
    Controls System
    Electrical
    Electrical 2015
    Mar 2010
    So~Cal
    106
    You define your grid in the properties of the project, the properties are propagated to the new drawings when you insert them or via the compare properties tool. If you want to change your grid sizes you can edit it in the project and apply the properties to all respective drawings rather then doing it manually.
    utilizing commands like:
    aeupdatesigref
    aeupdatesxref
    aexref
    will update the annotations on the drawings respective to your new grid configurations.
  1. 3D Solids of Cable Ladder
    By SAA84 in forum Blocks, Images, Models & Materials
    Last Post: 13th May 2015, 07:20 pm
  2. Replies: 20
    Last Post: 25th Oct 2013, 06:06 pm
  3. Insert a ladder sideways?
    By pqphillips in forum Electrical
    Last Post: 7th Jan 2013, 09:06 pm
  4. block that exist doesn't exist
    By dusko in forum AutoCAD Beginners' Area
    Last Post: 8th Jul 2010, 04:04 pm
  5. Need to revise VB code to read text from DWG
    By zer0_code in forum AutoLISP, Visual LISP & DCL
    Last Post: 16th Nov 2009, 04:44 pm
Tags for this Thread
