Page 2 of 2 FirstFirst 1 2
Results 11 to 16 of 16
  1. #11
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,156
    My $0.05 I am not an expert in 3d but this is my go at your problem. As full 3d. The arch cutouts should be located true tangent to the curved wall. If you want a 2d+ drawing then its possible to think about old fashioned flat plate unfolding eg funnel, by using arc lengths and lines vertically then a parabola joining the lines. yes a lisp would do that.
  2. #12
    Forum Deity steven-g's Avatar
    steven-g's Computer Details
    Win 7
    Construction
    steven-g's Discipline Details
    Draughtsman
    Construction
    I work in the estimating department of a large building contractor.
    AutoCAD 2018
    May 2013
    An Englishman in Belgium
    2,118
    Searching around, this type of question appears quite often but all I have found are references to Inventor and sheet metalwork. As BIGAL says in Autocad the only way I can see it being done is using mathematics (arc length, using center,start,length and then from there add in a height) but that only gives a series of points that you would need to join up, and you would need to decide what accuracy you need for that. And that only gives you a line drawing or points for a spline which is fine for a visual representation, but I don't know how you could then convert that to a true 3D model, such as a mesh or solid.
  3. #13
    Senior Member
    AutoCAD 2008
    Oct 2003
    Germany
    289
    Have a look at
    http://www.cadtutor.net/forum/showth...545#post624545
    too.
    Regards and good luck
    Jochen
  4. #14
    Forum Newbie
    SSArchi's Computer Details
    Windows
    AutoCAD 2015
    Oct 2015
    New York
    8
    Thank you so much for your help Steven-g! i will try the link and see if that technique works.
  5. #15
    Forum Newbie
    Windows
    AutoCAD 2015
    Oct 2015
    New York
    8
    Thank you scj
  6. #16
    Forum Newbie
    Windows
    AutoCAD 2015
    Oct 2015
    New York
    8
    Your technique appears promising. Thanks BIGAL
  1. curving a taper? magneto bucket.
    By digger2307 in forum SolidWorks
    Last Post: 28th May 2013, 02:57 pm
  2. in model space drawing showing colour when i move to layout drawing is white only
    By mihaf in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 26th Dec 2012, 02:25 pm
  3. curving corrigated object
    By azndelites in forum AutoCAD 3D Modelling & Rendering
    Last Post: 1st Apr 2010, 05:34 pm
  4. Curving Text
    By Alex Beardshaw in forum AutoCAD Beginners' Area
    Last Post: 12th Dec 2006, 02:02 pm
  5. prob: curving a 3d cone in acad
    By Hel1um in forum AutoCAD Drawing Management & Output
    Last Post: 30th Jun 2003, 06:28 am
