PDF Plot -- Filling Closed Polylines
parksj10
Hi all,
Got what I think is a dumb question I've been scouring for two hours. I use Civil 3D to create photomasks. It involves creating a lot of complex closed polylines that are filled during the conversion process to files such as GDSII.
What I'm trying to do is use the Plot function to generate a PDF for someone else to view that has all the closed polylines filled in. I've seen things like Fill,SHADEMODE, etc. but I can't seem to get the objects to fill in the drawing or rendered PDF.
I think the easiest thing you can tell me is from scratch, if I draw a RECT in a new .dwg file, how do I use PLOT in order to get a PDF that has the rectangle filled in?
Thanks a bunch!
Josh
EDIT: using Windows Version of Civil 3D Metric 2016
Thanks for the response. I thought about that, but I have thousands of objects that need to be filled in the pdf render. I feel like there should be an easy setting (like in my dxf conversion program) that simply fills the closed lines during plotting
In drafting, that is not a common thing to do. Sorry, no easy button included with AutoCAD for that, but I'm sure it could be done with LISP.
that sounds the route. 1 click, done.
OP - try posting what you want (hatch all closed polylines in the dwg with solid hatch) in the LISP sub-forum.
perhaps try searching the forum first - may have been discussed before.
See your other post please dont post twice its confusing.
I only posted twice because mikekmx told me to do so. Should I delete this one?
