How to import coordinates of the points of a geometry??
ali1234
Hi,
I am new in this forum.
I have a question:
I want to import coordinates of the points(x,y) of a geometry(2D) in autocad. But i don't know!
I am grateful that guide me about this case.
Thanks.
Best.
Ali
Edited by ali1234
Wether it be CSV or a delimted file
100,200,300 or 100 200 300 or +100 -200 +300 etc
There is lots of lisps to import into Autocad if its csv you only need to add LINE as the first bit of text and you can copy and paste all of it directly to command line.
The best answer is post your txt file and also a DWG showing the end result.
An example http://www.cadtutor.net/forum/showthread.php?94014-Custom-AutoLISP-command
Thanks for your answer,
Firstly I would say that I am new in autocad.
The coordinates is Naca 0020 profile as follows:
90    0    0
89.96049    0.00954    0
89.84214    0.03816    0
89.64513    0.08577    0
89.36982    0.15201    0
89.01666    0.23652    0
88.58628    0.33903    0
88.0794    0.45891    0
87.49692    0.59562    0
86.83992    0.74844    0
86.10957    0.91674    0
85.30704    1.09971    0
84.43377    1.29645    0
83.49138    1.50615    0
82.48149    1.72782    0
81.40572    1.96065    0
80.26623    2.20356    0
79.06482    2.45565    0
77.80356    2.71584    0
76.48488    2.98323    0
75.11085    3.25674    0
73.68408    3.53538    0
72.207    3.81807    0
70.68213    4.10391    0
69.11217    4.39182    0
67.5    4.68063    0
65.84832    4.96953    0
64.1601    5.25717    0
62.43822    5.54274    0
60.68574    5.82507    0
58.90572    6.1029    0
57.1014    6.37533    0
55.27575    6.64101    0
53.43219    6.89886    0
51.57378    7.14762    0
49.70376    7.38612    0
47.82555    7.6131    0
45.94239    7.8273    0
44.05761    8.02746    0
42.17445    8.21241    0
40.29624    8.3808    0
38.42622    8.53146    0
36.56781    8.66322    0
34.72425    8.77482    0
32.8986    8.86527    0
31.09428    8.93349    0
29.31426    8.97858    0
27.56178    8.99955    0
25.8399    8.99568    0
24.15168    8.96643    0
22.5    8.91108    0
20.88783    8.82945    0
19.31787    8.721    0
17.793    8.58582    0
16.31592    8.42382    0
14.88915    8.23518    0
13.51512    8.02017    0
12.19644    7.77933    0
10.93518    7.51302    0
9.73377    7.22214    0
8.59428    6.90732    0
7.51851    6.56955    0
6.50862    6.20964    0
5.56623    5.82876    0
4.69296    5.42799    0
3.89043    5.00832    0
3.16008    4.57092    0
2.50308    4.11687    0
1.9206    3.64734    0
1.41372    3.16323    0
0.98334    2.66544    0
0.63018    2.15505    0
0.35487    1.6326    0
0.15786    1.09899    0
0.03951    0.55458    0
0    0    0
0.03951    -0.55458    0
0.15786    -1.09899    0
0.35487    -1.6326    0
0.63018    -2.15505    0
0.98334    -2.66544    0
1.41372    -3.16323    0
1.9206    -3.64734    0
2.50308    -4.11687    0
3.16008    -4.57092    0
3.89043    -5.00832    0
4.69296    -5.42799    0
5.56623    -5.82876    0
6.50862    -6.20964    0
7.51851    -6.56955    0
8.59428    -6.90732    0
9.73377    -7.22214    0
10.93518    -7.51302    0
12.19644    -7.77933    0
13.51512    -8.02017    0
14.88915    -8.23518    0
16.31592    -8.42382    0
17.793    -8.58582    0
19.31787    -8.721    0
20.88783    -8.82945    0
22.5    -8.91108    0
24.15168    -8.96643    0
25.8399    -8.99568    0
27.56178    -8.99955    0
29.31426    -8.97858    0
31.09428    -8.93349    0
32.8986    -8.86527    0
34.72425    -8.77482    0
36.56781    -8.66322    0
38.42622    -8.53146    0
40.29624    -8.3808    0
42.17445    -8.21241    0
44.05761    -8.02746    0
45.94239    -7.8273    0
47.82555    -7.6131    0
49.70376    -7.38612    0
51.57378    -7.14762    0
53.43219    -6.89886    0
55.27575    -6.64101    0
57.1014    -6.37533    0
58.90572    -6.1029    0
60.68574    -5.82507    0
62.43822    -5.54274    0
64.1601    -5.25717    0
65.84832    -4.96953    0
67.5    -4.68063    0
69.11217    -4.39182    0
70.68213    -4.10391    0
72.207    -3.81807    0
73.68408    -3.53538    0
75.11085    -3.25674    0
76.48488    -2.98323    0
77.80356    -2.71584    0
79.06482    -2.45565    0
80.26623    -2.20356    0
81.40572    -1.96065    0
82.48149    -1.72782    0
83.49138    -1.50615    0
84.43377    -1.29645    0
85.30704    -1.09971    0
86.10957    -0.91674    0
86.83992    -0.74844    0
87.49692    -0.59562    0
88.0794    -0.45891    0
88.58628    -0.33903    0
89.01666    -0.23652    0
89.36982    -0.15201    0
89.64513    -0.08577    0
89.84214    -0.03816    0
89.96049    -0.00954    0
90    0    0
This way is difficult for me in this case.
I am grateful that guide me more about this problem.
Thanks.
Best.
Ali
NACA0020.txt
Took me about 10 seconds to import, opened in Notepad copied the big space which is a tab then used Replace pasting the copied blank tab and then replace with comma , replace all
Added LINE as first line then Ctrl A, CrtlC go to Autocad command line and paste Ctrl V all done.
LINE
90,0,0
89.96049,0.00954,0
89.84214,0.03816,0
89.64513,0.08577,0
LINE
90,0,0
89.96049,0.00954,0
89.84214,0.03816,0
89.64513,0.08577,0
Thanks for your answer, but I didn't understood your statement. maybe this is because my English language is not very good!
I didn't understood parts of your statement as follows:
replace with comma
What is your exact meaning of "blank tab" and "Replace pasting" and "big space which is a tab"?
How to replace with comma?
Thanks for allocating your time. I am grateful that guide me more.
Best.
Ali
What Al is saying is to use Notepad to edit the numbers by using EDIT -> REPLACE and replace ALL:
Replace the 4 spaces between the numbers with a comma:
"90 0 0" will become "90,0,0"
Hope this helps you.
  • 1 month later...
ACADMAP 2010 can import csv coordinates in many different formats
The only trouble I've seen that's adding lot of decimals to the elevation attribute and I don't know how to fix this
Does some one has nay clue?
E.g
Ac1,6377956.337,6138545.256,30.992,
is imported as a block with 2 attributes point name and elevation with a value like 30.9911993445666
I'm using arbitrary xy coordinates z in meters
I'd like to know is there is any way to limit decimal places to this attribute and why is changing the original value
I'll give a look to the block that acadmap is using
