Results 1 to 4 of 4
    Full Member
    AutoCAD 2012
    Aug 2015
    55
    Default Help with creating a solid out of faces.. or suggest a solution
    Hi all, For those who remember me, I'm working from my new upgraded computer now!! Core i5-2500, 8gigs ram, and a GTX960 video card. Things are running much faster these days from my old Pentium D life So, for my question.
    I need to create a solid box that is larger at the top than the bottom. The dimensions of top and bottom must be to spec. I can create it easily enough by creating a rectangle of specified size for the bottom, then one for the top and then change the elevation of the top.. I then connected all the corners using 3D Face command and I get a nice box like I need.
    The problem is, its not a solid, its just a bunch of 3d faces. I've tried a few different commands and none of them seem to do what I need. I think the closest I came was converting the faces to meshes, then into a solid. While that did work, it was a jumbo mess of lines.
    Can someone point me in the right direction please?
    Full Member
    AutoCAD 2012
    Aug 2015
    55
    I think I got it.. After creating the 3D faces, I had attempted to use several commands that failed. I saved the drawing, then when I came back and tried again it worked. I have no idea why.. (scratching head)
    Cad64's Computer Details
    Windows 7 Profesional x64
    XI Computers
    Asus P8Z77-V Pro
    24GB DDR3 @ 1333MHz
    SATAII 500GB 7200 RPM
    Multi-disciplinary
    Cad64's Discipline Details
    Freelance Digital Artist
    Multi-disciplinary
    3D model building, texturing and rendering. Photoshop Color Graphics.
    AutoCAD 2014
    Feb 2006
    Southern California
    10,139
    Another way to do this would be to create the 2 rectangles and then use the LOFT command to create the Solid model.
    CGSociety Portfolio: http://rdeweese.cgsociety.org/
    Facebook:
    https://www.facebook.com/rdeweese67/
    "Work Smart, Not Hard"
    Full Member
    AutoCAD 2012
    Aug 2015
    55
    You sir, are an Autocad God. Wow.. That command is going to save me so much time in the future.
    Thank you!
  1. change the angle between the two faces of 3D solid
    By 77077 in forum AutoLISP, Visual LISP & DCL
    Last Post: 27th Mar 2015, 03:09 pm
  2. 3D faces or surface to 3D solid model
    By nic6911 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 17th Sep 2013, 04:45 pm
  3. Extruding faces on a 3D solid question.
    By Cerberus in forum AutoCAD 3D Modelling & Rendering
    Last Post: 8th Nov 2010, 03:25 pm
  4. Rendering faces of a solid in 3D Max
    By xoom2 in forum UVW Mapping, Textures & Materials
    Last Post: 1st May 2004, 11:50 am
  5. Extrude faces on a solid
    By Orbit in forum AutoCAD General
    Last Post: 23rd Jun 2003, 04:56 pm
