Results 1 to 8 of 8
    Senior Member CafeJr's Avatar
    AutoCAD 2010
    Oct 2013
    Brazil, São Paulo, Sorocaba
    219
    Drawing Plot Views, sheets at the same Model Space.
    Hi to everyone!...
    Someone knows a Lisp to plot a internal sheets of a model space file? Eg.: I have a dwg file with 10 sheets internal, I know how to put name at each sheet (NEWVIEW) and it appears at same place of Extend, Display or Window at plot configuration screen. If I put names as a numbers: 1, 2, 3,..., 10, it's possible to select one page or all to plot at the same time? Or create a Lisp that can help it!?...
    Thanks in advance!...
    Its possible using a comand:
    -plot
    Detailed plot configuration? [Yes/No] <No>: y
    Enter a layout name or [?] <Model>:
    Enter an output device name or [?] <LaserJet 1320 PCL 6>: Canon iR2525
    Enter paper size or [?] <A4>:
    Enter paper units [Inches/Millimeters] <Inches>: m
    Enter drawing orientation [Portrait/Landscape] <Landscape>:
    Plot upside down? [Yes/No] <No>:
    Enter plot area [Display/Extents/Limits/View/Window] <Extents>: v
    Enter view name <>: 3 (the view name)
    Enter plot scale (Plotted Millimeters=Drawing Units) or [Fit] <Fit>:
    Enter plot offset (x,y) or [Center] <0.00,0.00>: c
    Plot with plot styles? [Yes/No] <Yes>:
    Enter plot style table name or [?] (enter . for none) <monochrome.ctb>:
    Plot with lineweights? [Yes/No] <Yes>:
    Enter shade plot setting [As displayed/legacy Wireframe/legacy Hidden/Visual styles/Rendered] <Legacy wireframe>:
    Write the plot to a file [Yes/No] <N>:
    Save changes to page setup [Yes/No]? <N>
    Proceed with plot [Yes/No] <Y>:
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,704
    Have a look at this I think you imply all is in model space. this is plot all in model space could be changed to views, plotting a range is achieveable by checking sheet id 1,2 ,3 etc Check my post
    http://www.cadtutor.net/forum/showth...Click-Printing
    AutoCAD 2010
    Oct 2013
    219
    Quote Originally Posted by BIGAL View Post
    Thanks Bigal!...
    Its help me alot!... Is exactly that I was looking for!...
    AutoCAD 2010
    Oct 2013
    219
    Bigal, do you know if is possible to get more than one item to select to print? At the first code!...
  5. #5
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,704
    If you look at my post in link above its a plot all. To only plot a few would require checking the sheet number an extra coding step. Or do by pick it would be easy to change the code to 1 at a time.
    Try
    Code:
    (setq ss2 (ssget "x" '((0 . "INSERT")
    replace with
    (setq ss2 (ssget "M" '((0 . "INSERT")
  6. #6
    AutoCAD 2010
    Oct 2013
    219
    Try
    Code:
    replace with
    Thanks Bigal!... It helps!..
    Someone knows how to do it to the Code at post #2 http://www.cadtutor.net/forum/showth...l=1#post459450
  7. #7
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,704
    There are many ways to pick which ones as I said before I would use a range of sheets to be plotted eg 7-10 and it would check each one picked in the "all" but only plot those within the range. See this example for layouts go down it has multiple layout routines.
    http://www.cadtutor.net/forum/showth...ts-Goto-layout
  8. #8
    AutoCAD 2010
    Oct 2013
    219
    Bigal!... Thanks a lot!!!...
  1. I have 2 views showing in model space...
    By kippax in forum AutoCAD Beginners' Area
    Last Post: 3rd Sep 2015, 04:02 pm
  2. No objects in Model space, But View ports has dwg views
    By RRS1987 in forum AutoCAD Drawing Management & Output
    Last Post: 4th Aug 2015, 01:48 pm
  3. Cannot plot model space
    By antistar in forum AutoLISP, Visual LISP & DCL
    Last Post: 12th Nov 2010, 09:34 pm
  4. Model Space Views ??
    By 4:3 in wide in forum AutoCAD General
    Last Post: 26th Aug 2009, 07:39 am
  5. Can not add model space view to sheets in PN
    By ktrides2 in forum Architecture & ADT
    Last Post: 11th Mar 2009, 02:24 pm
Tags for this Thread
