Plot Views, sheets at the same Model Space.
CafeJr
Hi to everyone!...
Someone knows a Lisp to plot a internal sheets of a model space file? Eg.: I have a dwg file with 10 sheets internal, I know how to put name at each sheet (NEWVIEW) and it appears at same place of Extend, Display or Window at plot configuration screen. If I put names as a numbers: 1, 2, 3,..., 10, it's possible to select one page or all to plot at the same time? Or create a Lisp that can help it!?...
Thanks in advance!...
Its possible using a comand:
-plot
Detailed plot configuration? [Yes/No] : y
Enter a layout name or [?] :
Enter an output device name or [?] : Canon iR2525
Enter paper size or [?] :
Enter paper units [inches/Millimeters] : m
Enter drawing orientation [Portrait/Landscape] :
Plot upside down? [Yes/No] :
Enter plot area [Display/Extents/Limits/View/Window] : v
Enter view name : 3 (the view name)
Enter plot scale (Plotted Millimeters=Drawing Units) or [Fit] :
Enter plot offset (x,y) or
: c
Plot with plot styles? [Yes/No] :
Enter plot style table name or [?] (enter . for none) :
Plot with lineweights? [Yes/No] :
Enter shade plot setting [As displayed/legacy Wireframe/legacy Hidden/Visual styles/Rendered] :
Write the plot to a file [Yes/No] :
Save changes to page setup [Yes/No]?
Proceed with plot [Yes/No] :
Have a look at this I think you imply all is in model space. this is plot all in model space could be changed to views, plotting a range is achieveable by checking sheet id 1,2 ,3 etc Check my post
http://www.cadtutor.net/forum/showthread.php?67143-One-Click-Printing
Thanks Bigal!...
Its help me alot!... Is exactly that I was looking for!...
If you look at my post in link above its a plot all. To only plot a few would require checking the sheet number an extra coding step. Or do by pick it would be easy to change the code to 1 at a time.
Try
(setq ss2 (ssget "x" '((0 . "INSERT")
replace with
(setq ss2 (ssget "M" '((0 . "INSERT")
Try
replace with
Thanks Bigal!... It helps!..
Someone knows how to do it to the Code at post #2 http://www.cadtutor.net/forum/showthread.php?67143-One-Click-Printing&p=459450&viewfull=1#post459450
There are many ways to pick which ones as I said before I would use a range of sheets to be plotted eg 7-10 and it would check each one picked in the "all" but only plot those within the range. See this example for layouts go down it has multiple layout routines.
http://www.cadtutor.net/forum/showthread.php?84430-Move-layout-Rename-layouts-Goto-layout
Bigal!... Thanks a lot!!!...
