Results 1 to 4 of 4
    Forum Newbie
    Manufacture
    Ranime's Discipline Details
    Industrial Engineer
    Manufacture
    AutoCAD 2015
    Jun 2015
    Lebanon
    8
    Default Array Number/Count Dynamic Block
    I have the following block where I have successfully inserted stretch action (no limits) and array action (limit 20). I need to display the array count number next to the block so that I don't have to count the aisles every time I have to use the action.
    Dynamic Array Count.dwg
    Forum Deity steven-g's Avatar
    steven-g's Computer Details
    Win 7
    Construction
    steven-g's Discipline Details
    Draughtsman
    Construction
    I work in the estimating department of a large building contractor.
    AutoCAD 2018
    May 2013
    An Englishman in Belgium
    2,165
    Take a look at the attached, there are probably other methods but this works fine.
    By the way, be aware of your block insertion point - the geometry in your block is a long way from the origin.
    Forum Newbie
    Manufacture
    Industrial Engineer
    Manufacture
    AutoCAD 2015
    Jun 2015
    Lebanon
    8
    Steven-g what a genius! I can never think of this. Thank you very much. Is there any way to make it update automatically when I drag it? or the only way is to regen?
    Win 7
    Construction
    Draughtsman
    Construction
    AutoCAD 2018
    May 2013
    2,165
    No unfortunately it needs a regen.
  1. Dynamic Block Array
    By y061q in forum AutoCAD Drawing Management & Output
    Last Post: 2nd Jan 2013, 07:11 pm
  2. Adding Array Count to Dynamic Blocks?
    By TuFoFi in forum AutoCAD Drawing Management & Output
    Last Post: 25th Oct 2012, 03:35 pm
  3. Question about the dynamic block count in a data extraction table
    By Jpier in forum AutoCAD Beginners' Area
    Last Post: 16th Dec 2010, 02:03 pm
  4. How to Count number of ocurances of a letter in block text
    By stockers in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 23rd Dec 2009, 08:45 am
  5. Array in Dynamic block
    By MvdS in forum AutoCAD General
    Last Post: 23rd Mar 2009, 01:13 pm
Tags for this Thread
