Ranime
I have the following block where I have successfully inserted stretch action (no limits) and array action (limit 20). I need to display the array count number next to the block so that I don't have to count the aisles every time I have to use the action.
Dynamic Array Count.dwg
Take a look at the attached, there are probably other methods but this works fine.
By the way, be aware of your block insertion point - the geometry in your block is a long way from the origin.
Count.dwg
Steven-g what a genius! I can never think of this. Thank you very much. Is there any way to make it update automatically when I drag it? or the only way is to regen?
