Page 2 of 2 FirstFirst 1 2
Results 11 to 20 of 20
  1. #11
    Junior Member
    AutoCAD 2015
    Oct 2015
    13
    You may have to resort to using the THICKEN command.
    That's brilliant and worked really well for the base, unfortuantly the sides of the hull yielded this;
    "surfaces cannot be thickened with specified value. Object intersects itself."
    Is there anyway around that?
  2. #12
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,630
    Yes, fix your geometry.
  3. #13
    Junior Member
    AutoCAD 2015
    Oct 2015
    13
    Ah, why do I have a feeling that is the same as going right back to the beginning. The hull geometry is both concave and convex and unless I work outside the GA drawings I can't see any way I could clean the geometry up. This is what I have now the loft command is run but it has only created a surface and I really need a solid:
  4. #14
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,630
    When you attempted to use the thicken command what thickness did you specify?
  5. #15
    Junior Member
    AutoCAD 2015
    Oct 2015
    13
    I started quite large without meaning too, I started with about +1.0m, after realising my mistake I then tried +0.1, then +0.0001. All resulted in the same.
  6. #16
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,630
    Without an actual copy of the drawing to experiment with I can't give you a definitive answer one way or the other.
    I think you should find a more suitable program for doing hull design other than AutoCAD.
  7. #17
    Junior Member
    AutoCAD 2015
    Oct 2015
    13
    I will carry on playing with it, hopefully its just me not explaining things very well :-)
    File attached for anyone interested
    AHV.dwg
  8. #18
    Junior Member
    AutoCAD 2015
    Oct 2015
    13
    I have done it :-) So in the end I basically created a Keel level planar surface which I then extruded into a solid to the height of the next deck, I then used the "lofted" surface to slice the shape I needed Thanks again for all of your help with this
  9. #19
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,630
    You're entirely welcomed but to be truthful I really didn't provide that much help. You basically did it all on your own. Congrats.
  10. #20
    Junior Member
    AutoCAD 2015
    Oct 2015
    13
    Not at all, I would not have known about most of the commands if I had not read many of your responces in other posts. Much appreciated :-)
  1. Cutting a hole in a solid, and making a circle a solid.
    By mike Keith in forum AutoCAD 3D Modelling & Rendering
    Last Post: 21st Nov 2016, 02:05 pm
  2. how to made a 3d solid soccer ball
    By buburayak in forum AutoCAD 3D Modelling & Rendering
    Last Post: 15th Mar 2010, 03:51 pm
  3. Confused on making a simple circle
    By SFG13 in forum AutoCAD Beginners' Area
    Last Post: 21st Jan 2010, 12:02 am
  4. Can this object be made of solid?
    By didko in forum AutoCAD 3D Modelling & Rendering
    Last Post: 26th Nov 2008, 01:56 am
  5. ...create a complex 3d solid (sailboat hull)
    By ledo in forum AutoCAD General
    Last Post: 7th Jul 2005, 04:38 pm
