Change block A inside block B using block B's attribute
Gotrekk
Hi everyone,
- i have a block called "car", with an attribute called "wheel_att".
- i have four different blocks called wheelA, wheelB, wheelC, wheelD with different shapes etc.
- inside that "car" block, i create a block called "wheel".
- i now have hundreds "car" blocks with the attribute "wheel_att" set as "wheelA", "wheelB", "wheel_C" or "wheel_D"
is there a way to change the "wheel" block inside each "car" block using the attribute "wheel_att"?
i hope i've been clear enough on the explanation! thanks in advance!
What are you looking to change exactly?
From your post I have understood:
'CAR' has attribute 'WHEEL_ATT'
'CAR' contains nested block 'WHEEL'
If this is the case, you will not be able to change WHEEL per reference of CAR as any change to the definition of CAR will be reflected across all references.
Yes Lee, you got my problem and i think i understand what you mean.
Should i try using a dynamic block with visibility states like "wheelA", "wheelB" and so on, showing only the "wheel" i need? Would i be able to set the visibility state from an attribute?
Example:
i have many cars with "rounded wheels" and many with "squared wheels".
I have the "car" block with attribute "wheel_att" containing either "round_wheel" or "square_wheel".
How can i display those cars with the appropriate wheels design?
I don't want to create separate squared_wheels_car and rounded_wheels_car blocks because i have other attributes defining other car parts like door, cockpit and so on
What would it be the best way of doing it?
thanks again
Yes, you could use a dynamic block with visibility states; though, the easiest way would be to simply not nest the wheel block within the car block, but maybe group the wheel block with the car block if necessary.
