Mogie Posted October 16, 2015 Share Posted October 16, 2015 Using 2013, my multileader text box seems to interpret the space bar as Enter. Hence I can't seem to enter more than 1 word at a time. However, if I use the multileader with the single word it edits the Mtext as normal ie. the space bar works as a space bar! Many thanks in advance. Quote Link to comment Share on other sites More sharing options...
PhilJ Posted November 24, 2015 Share Posted November 24, 2015 Hi Mogie, had the same problem with multileader initiated from abbreviation in acad.lsp pointing to the mleader command. the mtext works normally if you use the full command (mleader) at the command prompt or if you initiate it with your shortcut in the acad.pgp file. Quote Link to comment Share on other sites More sharing options...
Mogie Posted November 29, 2015 Author Share Posted November 29, 2015 Brilliant! That seems to have solved the problem, many thanks Phil. Quote Link to comment Share on other sites More sharing options...
