Results 1 to 4 of 4
    Forum Newbie
    AutoCAD 2000
    Sep 2006
    Richmond, VA
    2
    Default Changing units in AutoCAD 2000
    Hi, I'm new here.
    My main question is: How do I go from taking a file with a unitless .dwg (in terms of measure, in this case its in pixels/bitmap level) and covert it to a unit (I want a pixel to be 12.05 um in pitch)? Can anyone help me? I'm still pretty new to A.C. I tried to take the .DWG into Adobe Illustrator, but unfortunately, that cad program likes to work w./ a precision of three decimals to the right (plus the programs works between a metric system and points, creating some inprecision later on). I'd appreciate any added advice or solutions. Thanks.
    -SKumar
    Super Moderator f700es's Avatar
    f700es's Computer Details
    Windows 7 Pro (W)/Windows 7 Home Premium (H)
    Lenovo ThinkStation D20 (W)/ Dell Inspiron 570 (H)
    Intel (W)/AMD (H)
    Intel Xeon E5503 (W)/AMD Athlon 2 X4 (H)
    4 GB DDR3 (W)/ 6GB DDR3 (H)
    nVidia Quadro FX 580 (W)/nVidia GF GT430 (H)
    500 GB HDD (W)/1 TB (H)
    Seagate FreeAgent Go 320gb
    Samsung P2770HD 28" LCD and Samsung B2430 (W)/Dell 22" LCD (H)
    Facilities Mgmt
    f700es's Discipline Details
    Space Database Admin
    Facilities Mgmt
    Archibus Management
    AutoCAD 2013
    Sep 2002
    Winston-Salem, NC - USA
    4,508
    Quote Originally Posted by SKumar View Post
    Hi, I'm new here.
    -SKumar
    Welcome SKumar. 1st off AutoCAD is a vector program so there are no pixels. Your drawing has a unit setup already just not sure which. Type "ddunits" at the command line to see what it is set at. Here you can also change the units. Now if you are going from say Metric to US Standard you will need to scale your drawing as well. Put let's see what yours is set at what you want it to be. Good luck
    PS. I have some experience with Acad and Illustrator so we can work that out as well.
    Please do not PM me with CAD questions. Post your question on the forum. Our users are the best out there and you'll get the best possible answer to your question.
    - http://f700es.deviantart.com/gallery/ -
    Forum Newbie
    AutoCAD 2000
    Sep 2006
    Richmond, VA
    2
    f700es, thanks for the awesome help thus far. I did what you suggested, and its listed as "Unitless." I apologize for stating "pixels" in my first post since this is a vector-based program, but I couldn't think of what I would call it, other than just units. My next question is how or what do I do to get one unit in the drawing to be equal to 0.0125 mm (12.5 microns)? I appreciate yours or anyone's help. Thanks.
    -SKumar
    Luminous Being StykFacE's Avatar
    StykFacE's Computer Details
    Windows 7 Ultimate 64bit
    Dell Precision T3500
    Multi-disciplinary
    StykFacE's Discipline Details
    BIM Manager & Design Specialist
    Multi-disciplinary
    Facilities engineering, involving mechanical piping, mechanical HVAC and electrical engineering.
    Revit 2013
    Mar 2006
    Dallas, TX - USA
    6,584
    i'm assuming you're trying to draw to a specific scale - don't do that. Draw everything as 1:1, if you need to scale your drawing for printing purposes, go to Paperspace (a.k.a. Layout1 Tab, etc) and scale your Viewport using the Properties box. you can choose one of the many preset scales, or use your own. hope i'm on the right track of what you're trying to accomplish.
    Tannar Frampton | Facilities Engineering | Revit 2013
    Personal Projects | Fender Squier Stratocaster | Custom Smoker | Concrete Patio
  1. changing default units to fractional
    By steve28 in forum AutoCAD Beginners' Area
    Last Post: 1st Mar 2006, 10:24 pm
  2. Network problem in AutoCad 2000 + Win 2000
    By xper_mental in forum AutoCAD Drawing Management & Output
    Last Post: 24th Jan 2006, 04:45 pm
  3. Units changing after save
    By /\/lg|-|T/\/\@R3 in forum AutoCAD Drawing Management & Output
    Last Post: 12th Jan 2006, 08:55 pm
  4. Changing Units to only inches
    By CADGal in forum AutoCAD Beginners' Area
    Last Post: 21st Sep 2004, 04:26 pm
  5. changing from acad 2000 to 2004
    By hump8888 in forum AutoCAD Drawing Management & Output
    Last Post: 5th Aug 2004, 06:49 pm
