Results 1 to 5 of 5
    Full Member
    AutoCAD 2015
    Jun 2015
    Tulsa, OK
    39
    Default Revision Cloud Help on Sheet
    Hello,
    I am using Revit 2015 and I had to add a revision to two sheets. They both use the same title block and they are the only two sheets in the revision. One of the title blocks acts as it should and shows the revision number and date on the title block in the revision section, but the other sheet does not. Has anyone had this happen before and if so do you know what to do?
    Thanks in advance
    Luminous Being tzframpton's Avatar
    tzframpton's Computer Details
    HP Zbook
    Multi-disciplinary
    tzframpton's Discipline Details
    BIM Specialist
    Multi-disciplinary
    Full Virtual Design and Construction BIM services for the MEP engineering and construction industries.
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,119
    1. Are the Revisions placed in the View, or on the physical Sheet?
    2. Have you checked to see if the revision is hidden? If the revision is hidden it won't display in the titleblock.
    Tannar Z. Frampton ™ | Frampton & Associates, Inc.
    Full Member
    AutoCAD 2015
    Jun 2015
    Tulsa, OK
    39
    Hello, sorry for the late response I was on lunch. A co-worker of mine figured it out. The revision schedule is inside the title block family and he noticed that the itemize every instance box was not checked in the schedule so it was only showing the revision information on the first sheet to have a revision cloud added to it. After he checked the box and loaded the family back into the project all of the sheets started showing the revision information.
    HP Zbook
    Multi-disciplinary
    BIM Specialist
    Multi-disciplinary
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,119
    Good deal. Glad you got it figured out.
    -TZ
  5. #5
    Full Member
    AutoCAD 2015
    Jun 2015
    Tulsa, OK
    39
    Thank you for responding to my post, I appreciate all the help from this site!
  1. new linetype for revision cloud
    By mabo86 in forum Student Project Questions
    Last Post: 24th Oct 2012, 11:40 am
  2. Convert spline to revision cloud
    By vnanhvu in forum AutoLISP, Visual LISP & DCL
    Last Post: 7th Jun 2011, 06:48 am
  3. Revision Cloud line weight
    By darrellk-1 in forum AutoCAD General
    Last Post: 7th May 2009, 12:38 am
  4. Revision Cloud
    By sparkyuk in forum AutoCAD Beginners' Area
    Last Post: 23rd Oct 2008, 03:53 pm
  5. inverse revision cloud
    By Scale in forum AutoCAD Drawing Management & Output
    Last Post: 27th Sep 2007, 04:02 pm
Tags for this Thread
