Results 1 to 9 of 9
    Forum Newbie
    Manufacture
    King Louie's Discipline Details
    Draftsman, steel industry
    Manufacture
    I work in the drafting/detailing department for a major construction manufacturer. I am a detailer/checker and a program tester for our CAD package.
    AutoCAD 2011
    Dec 2012
    5
    Question Shift to add to selection (PICKADD) - shortcut key option to toggle?
    If this is posted elsewhere, I apologize, but I couldn't come across anything...
    Users will come to me occasionally telling me that they can't pick more than one object. I know to go to Options, Selection tab, and uncheck the checkbox for hold Shift to add to selection set. I also know about the related PICKADD setting.
    What I want to know is if there is some sort of hotkey, SHIFT+something, etc. to toggle this on/off. I am kind of our detailing software tester/guru, and see this from time to time. When I'm asked about it, I can fix it for them, but I can't tell them what they did to cause it. Anyone?
    Thanks in advance!
    AutoCAD 2013
    Nov 2011
    5,976
    The most likely culprit for changes in the PICKADD system variable setting would be a poorly written lisp, which fails to restore the previous setting upon an abort or escape, mid execution of the lisp. Are the users in question using personalized PROFILES, or the default Autocad profile?
    I know you said you understand the PICKADD settings, but in case someone else might not, I have attached a screenshot from the SYSVDLG box.
    Wherein, I might add, one can use the SAVE ALL option to create an .svf (system variable file), which is always a good thing to have, and will one day come in very handy, unless of course you have never created one, at which time you will wish that you had.
    Forum Newbie
    Manufacture
    Manufacture
    AutoCAD 2011
    Dec 2012
    5
    Our users don't write any of their own LISPs or routines, and are not manipulating PICKADD themselves. It's all done under the hood for us through functionality built by our own internal IT group. If that is the case, chances are, except for maybe exiting a certain routine without completing it, there's not really anything the users might be doing. The fun part would be identifying which routine(s) are at fault.
    Thanks for the guidance.
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,169
    Quote Originally Posted by King Louie View Post
    That is a probable cause.
    Drafting is a breeze.
  5. #5
    AutoCAD 2013
    Nov 2011
    5,976
    I am illisperate, but have great appreciation for those who are amongst the lisperati, lots of forum members fall into that club. I use a great many of LeeMac;s wonderful lisps on a regular basis, and they save me lots of time and effort. Thanks Lee!
    This link from Lee's site http://www.lee-mac.com/errorhandling.html
    may shine further light on the issue of which I spoke in my earlier post, and may be a good starting point for anyone looking to check your in house lisps for inadequate error handling.
  6. #6
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2018
    Feb 2010
    Oviedo, Florida
    4,717
    There is a toggle switch for PICKADD up at the top right of the Properties dialog box. It's in the same place in all versions of Vanilla AutoCad. Tell you people to stop playing with the buttons.
    One way to fix this is to copy that button to their ribbon or toolbar in the CUI and give it a text label.
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
  7. #7
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,169
    Good one, Dana. I always forget that that is there.
  8. #8
    Forum Newbie
    Manufacture
    Manufacture
    AutoCAD 2011
    Dec 2012
    5
    THAT is something I can see our users getting into by accident. I think I might pass that one along... I didn't realize it was there, either. I'm a keyboard shortcut guy, but I tell users to keep their properties palette open on auto-hide... although some lose patience with the auto-hide behavior, when it flies out on them when they don't want it to...
    Thanks again to all!
  9. #9
    AutoCAD 2013
    Nov 2011
    5,976
    I am a huge fan of the QUICK PROPERTIES, over the standard PROPERTIES, because it can be customized to show you exactly what you feel is needed, and nothing more.
    Not for everybody, but I find it very helpful.
  1. Selection Box to toggle between objects APPEARS UNWANTED
    By luis oliveira in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 13th May 2010, 03:00 pm
  2. Additional uses of the Shift key as a shortcut
    By AutoCAD Tips Blog in forum AutoCAD RSS Feeds
    Last Post: 9th Jul 2009, 03:10 am
  3. Use the Shift key as a shortcut
    Last Post: 29th Jun 2009, 09:50 pm
  4. Shortcut Option Menus
    By andrewjbarnett in forum AutoCAD Beginners' Area
    Last Post: 23rd Feb 2009, 03:53 am
  5. CNTRL to toggle selection for CAD 2008
    By ed_MRA in forum AutoCAD Drawing Management & Output
    Last Post: 9th Jan 2008, 09:30 pm
