kizaerf Posted October 19, 2015 Share Posted October 19, 2015 Both of these lines are shown as being 180 degrees (i.e. horizontal) but clearly they aren't. How do I fix this? I tried fixing the UCS to be 'world' Quote Link to comment Share on other sites More sharing options...
ROBP Posted October 19, 2015 Share Posted October 19, 2015 Both of these lines are shown as being 180 degrees (i.e. horizontal) but clearly they aren't. How do I fix this? I tried fixing the UCS to be 'world' Post dwg so we can examine it, could be that both perpendicular lines you are trying to join are not equal seen it so often. Quote Link to comment Share on other sites More sharing options...
ROBP Posted October 19, 2015 Share Posted October 19, 2015 if line is straight it could be that all the other ones are not starting at the same point construction lines will tell Quote Link to comment Share on other sites More sharing options...
rkent Posted October 19, 2015 Share Posted October 19, 2015 Check the Y coordinates, they don't match on the lower image. You need to start the units command and change the precision to see the actual angle. Quote Link to comment Share on other sites More sharing options...
nukecad Posted October 20, 2015 Share Posted October 20, 2015 As rkent says that second one has different ordinates on the Y value so is not horizontal. You can also see this by the 'delta Y' reading. Your angle readout is only showing whole degrees so this slight difference does not show there. Use AUPREC to change this to show partial degrees rather than just whole degrees and you will see the difference there as well. Quote Link to comment Share on other sites More sharing options...
eldon Posted October 20, 2015 Share Posted October 20, 2015 If you have never altered the Angle unit precision, it defaults to 0. Therefore the angle can be plus or minus half a degree before the angle shows any different. As you have noticed, you can see any slight deviation from the x or y axis, but this deviation is smaller than half a degree, so the angle still shows as 0, 90, 180 or 270. Quote Link to comment Share on other sites More sharing options...
