Page 2 of 2 FirstFirst 1 2
Results 11 to 17 of 17
  1. #11
    Forum Newbie
    AutoCAD 2013
    Oct 2015
    7
    Ok tanks guys, I will look for dynamic blocks and xdata and come back in an other thread if I have questions.
  2. #12
    Senior Member
    AutoCAD 2016
    Jan 2012
    155
    I think there has been a lot of misunderstanding here. You must go to the AutoCAD help and study the difference between the properties, dynamic blocks, attributes, xdata and fields.
  3. #13
    Forum Newbie
    AutoCAD 2013
    Oct 2015
    7
    I will go to the Autocad help and study the differences between those things.
    Can you clarify the misunderstandings ? What am I understanding wrongly ?
  4. #14
    Senior Member
    AutoCAD 2016
    Jan 2012
    155
    I just have a feeling that we are talking past each other and not really talking about the same thing.
  5. #15
    Forum Newbie
    AutoCAD 2013
    Oct 2015
    7
    Hum, ok. What I understood of that thread is that adding custom properties to an object is impossible. I have to either convert the object into a dynamic block, or use xdata.
  6. #16
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,161
    As suggested before, a regular block with attributes can hold that data for you. AutoCAD's help can be very confusing, please feel free to continue to ask your questions here.
    Drafting is a breeze.
  7. #17
    Super Member
    tombu's Computer Details
    Windows 7 64-bit
    Dell
    Civil
    tombu's Discipline Details
    Design Analyst
    Civil
    Small Street & Stormwater projects. Traffic Calming and other issues.
    Civil 3D 2018
    Dec 2010
    Tallahassee, FL USA
    716
    Quote Originally Posted by koudougou View Post
    Thank you also for your answer, and the clarification about the name of the differents boxes.
    What the employees are asking is to fill some custom fields on their drawings and that those custom attributes and values can later be found in the dxf file, so other tools processing the dxf file can find the regular attributes and their values but also the custom ones.
    So, conclusion : we can't add custom properties to an object with Autocad 2013. I have to turn objects into blocks and then use attributes to add custom information. Am I right ?
    Yes and no. It can be done with AutoCAD Map as this it typical for GIS data. While they show up in the Properties Palette they are not output by the list command and can only be accessed by AutoCAD Map which I doubt would help you.
  1. properties menu
    By JasonS1500 in forum AutoCAD Beginners' Area
    Last Post: 20th Aug 2013, 08:56 pm
  2. Adding fields to polylines properties
    By falcon900 in forum Civil 3D & LDD
    Last Post: 13th Jun 2012, 11:57 am
  3. Properties menu not working
    By Jon McElwain in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 20th Mar 2012, 07:14 pm
  4. adding custom properties
    By orange in forum AutoCAD General
    Last Post: 22nd Jul 2011, 10:42 am
  5. AutoCAD 2009 - Rollover Tool Tips for Object Properties
    By Between the Lines in forum AutoCAD RSS Feeds
    Last Post: 28th Feb 2008, 01:56 pm
Tags for this Thread
