Results 1 to 8 of 8
    Senior Member teknomatika's Avatar
    AutoCAD 2009
    Sep 2010
    Portugal
    247
    Default Export layers list (only a selection)
    I have this routine (unknown to the author). Thank you for your help with the following change: Export the list of layers but only on a selection.
    Code:
    (defun c:LL2T ( / oecho clrlst dwgnm fn fh lyr lyrlst)
    (defun chkbit (bit_val num)
    (not (zerop (logand bit_val num)))
    (setq
    oecho (getvar "cmdecho")
    clrlst (list
    (cons 1 "RED")
    (cons 2 "YELLOW")
    (cons 3 "GREEN")
    (cons 4 "CYAN")
    (cons 5 "BLUE")
    (cons 6 "MAGENTA")
    (cons 7 "WHITE")
    dwgnm (getvar "dwgname")
    (setvar "cmdecho" 0)
    (setq fn (getfiled " File name: " (strcat dwgnm ".LS") "LS" (+ 1 2))
    (while (setq lyr (tblnext "layer" (not lyr)))
    (setq lyrlst (cons (cdr (assoc 2 lyr)) lyrlst))
    (setq lyrlst (acad_strlsort lyrlst))
    (princ "\nWriting layer data to file...")
    (setq fh (open fn "w"))
    (princ (strcat dwgnm ".DWG\n") fh)
    (foreach x lyrlst
    (setq
    lyr (tblsearch "layer" x)
    lyrname (cdr (assoc 2 lyr))
    lyrclr (cdr (assoc 62 lyr))
    lyrlt (cdr (assoc 6 lyr))
    frzn? (chkbit 1 (cdr (assoc 70 lyr)))
    lokd? (chkbit 4 (cdr (assoc 70 lyr)))
    (if (minusp lyrclr)
    (setq
    on? "OFF"
    lyrclr (abs lyrclr)
    (setq on? "ON")
    (if (assoc lyrclr clrlst)
    (setq lyrclr (cdr (assoc lyrclr clrlst)))
    (if frzn?
    (setq frzn? "FROZEN")
    (setq frzn? "THAWED")
    (if lokd?
    (setq lokd? "LOCKED")
    (setq lokd? "UNLOCKED")
    (princ lyrname fh)
    ;;(princ "," fh)
    ;;(princ lyrclr fh)
    ;;(princ "," fh)
    ;;(princ lyrlt fh)
    ;;(princ "," fh)
    ;;(princ on? fh)
    ;;(princ "," fh)
    ;;(princ frzn? fh)
    ;;(princ "," fh)
    ;;(princ lokd? fh)
    (princ "\n" fh)
    (princ "done.")
    (close fh)
    (setvar "cmdecho" oecho)
    Lee Mac's Computer Details
    Win 7 Pro / Win 10 Pro / Linux Mint
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,600
    Here is a similar program with a few more options - also, note that you can select layers from the Layer Manager and copy them directly.
    Lee Mac ProgrammingTwitterExchange App StoreDropbox (500MB free)
    AutoCAD 2009
    Sep 2010
    Portugal
    247
    Lee, fantastic tool, as expected. Thank you for your statement. Already I kept. However, for this, I just want to extract the names of the layers contained in a selection, not the entire design.
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,600
    Maybe something like this?
    Code:
    (defun c:layernames ( / f l s x )
        (if (and (setq s (ssget))
                 (setq f (getfiled "Create File" "" "txt" 1))
            (if (setq f (open f "w"))
                    (repeat (setq i (sslength s))
                        (or (member (setq x (cdr (assoc 8 (entget (ssname s (setq i (1- i))))))) l)
                            (and (write-line x f)
                                 (setq l (cons x l))
                    (close f)
                (princ "\nUnable to open file for writing.")
    [Untested]
  5. #5
    AutoCAD 2009
    Sep 2010
    Portugal
    247
    Lee, that's exactly. Better, just even making out the list sorted alphabetically. Thank you!
  6. #6
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,600
    Quote Originally Posted by teknomatika View Post
    You're welcome! - For an alphabetically sorted output, try the following:
    Code:
                            (setq l (cons x l))
                    (foreach x (acad_strlsort l) (write-line x f))
                    (close f)
  7. #7
    AutoCAD 2009
    Sep 2010
    Portugal
    247
    Lee, you're the best. But also generous. Thank you!
  8. #8
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,600
  1. Export cui as indented text list
    By samifox in forum The CUI, Hatches, Linetypes, Scripts & Macros
    Last Post: 25th Apr 2015, 03:03 am
  2. List box selection changes radio_row selection?
    By LosGirk in forum AutoLISP, Visual LISP & DCL
    Last Post: 9th Jan 2015, 07:19 am
  3. how can i exclude the xref layers from the layers list?
    By samifox in forum AutoCAD General
    Last Post: 7th Mar 2014, 02:49 pm
  4. List to Selection set
    By satishrajdev in forum AutoLISP, Visual LISP & DCL
    Last Post: 1st Nov 2013, 02:37 pm
  5. Export your layer list to Excel
    By CAD Panacea in forum AutoCAD RSS Feeds
    Last Post: 17th Aug 2011, 12:50 pm
Tags for this Thread
