Results 1 to 4 of 4
Thread: Polyline width
    Full Member
    AutoCAD 2011
    Oct 2010
    42
    Default Polyline width
    I need to create custom linetypes where batting line is certain width.
    For example BATTING_50mm, BATTING_100mm etc linetypes, so I don't have to mess around wth each single line. I can just select certain linetype and start drawing. How do I do that?
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2018
    Feb 2010
    Oviedo, Florida
    4,723
    Search for Batting here on the forum. There must be 100 threads about it, anything from custom line types, to dynamic blocks, to hatching.
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,025
    Like Dana said my version is based around 100mm and you just fuzz factor it for other sizes so only 1 lisp that draws a pline, multiple versions.
    Full Member
    AutoCAD 2011
    Oct 2010
    42
    I've searched, didn't find anything that's easy to follow.
    I want to create new linetype by copying and modifying an existing one and then assign different widths to them. When I'd change the scale, lines would stay the same.
    Nothing to do with dynamic blocks and hatches.
  1. Polyline Width
    By Scoobydoo in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 30th Dec 2010, 06:54 pm
  2. Polyline Width
    By ML_Halcrow in forum AutoCAD General
    Last Post: 16th Apr 2010, 01:45 pm
  3. Polyline Width
    By Tconn in forum AutoCAD Drawing Management & Output
    Last Post: 20th Jun 2007, 09:36 am
  4. Polyline width
    By viriato79 in forum AutoCAD Beginners' Area
    Last Post: 31st Mar 2006, 02:10 pm
  5. polyline width
    By cadam in forum AutoCAD Drawing Management & Output
    Last Post: 5th Feb 2004, 03:31 pm
