Results 1 to 3 of 3
    Junior Member
    AutoCAD 2015
    Oct 2015
    19
    Default Replace parametr type dynamic block
    Is it possible to change the position parameters at properties menu? For example, (as shown in the screenshot) "Distantce3" move to the first line, and "Distance1" on the third line.
    I need it, for example if there is a dynamic block with many parameters. And to add one parameter - AutoCAD default setting makes this the bottom line in the properties. And I need that to this option in the properties was the first line.
    Senior Member zaphod's Avatar
    AutoCAD 2017
    Sep 2013
    Houston, TX
    175
    in 2013 if you use the prameters manager in the block and select "convert parameter" for D1 and D2, then convert them back D3 will be at the top of the list, not exactly easy or fast.
    Junior Member
    AutoCAD 2015
    Oct 2015
    19
    In "Parameters manager" in the block I find column "Order" and the problem is solved. Thank you!
  1. LISP to replace blocks with Dynamic block with set visibility states.
    By Glen1980 in forum AutoLISP, Visual LISP & DCL
    Last Post: 15th Oct 2015, 05:33 pm
  2. Replace dynamic blocks by another ones
    By alijahed in forum AutoCAD Drawing Management & Output
    Last Post: 3rd Oct 2014, 12:05 am
  3. block replace and dynamic blocks
    By Glen Smith in forum AutoCAD Drawing Management & Output
    Last Post: 16th Jul 2014, 07:27 pm
  4. Insert dynamic block,error: bad argument type: lentityp nil
    By liuhaixin88 in forum AutoLISP, Visual LISP & DCL
    Last Post: 17th Feb 2014, 11:19 pm
  5. How to replace dynamic block in a drawing without losing data?!
    By ibach in forum AutoLISP, Visual LISP & DCL
    Last Post: 12th Jan 2013, 06:48 pm
