Page 1 of 2 1 2 LastLast
Results 1 to 10 of 17
    Full Member
    AutoCAD LT 2014
    Mar 2015
    28
    Default Object selection
    Can anyone please help ..
    i have a curved 3d polyline that i need to offset autocad lt 2014 wont allow me to do this unless i explode the line, the only issue is that i then have to offset hundreds of individual lines, which i can accept but then i need to select these lines created by the offset to give them a new layer//linetype, etc .. is there any way i can select the items i created on the last operation ie offset . i can do it and it selects the very last line... but am needing it to do for the whole operation .. i hope you understand what i mean ..or am i just going about this the wrong way ??
    Thanks for reading .
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,879
    Too bad you are using LT and not full AutoCAD because I found a custom lisp routine for offsetting a 3D polyline that works.
    How many 3D polylines do you have to offset?
    Full Member
    AutoCAD LT 2014
    Mar 2015
    28
    yeah it kinda blows about lisps not working on lt
    i have only about 3100 individual pieces !! .. .. do you know if you can offset in two directions at once .. am basically showing cable that is in ducting so needing parallel lines on both sides .. there's miles and miles of it .. if i could offset in both directions at once it would cut it down by half.. two thirds away threw now but its just in-case i come across this again ...
    thanks for your response
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,879
    The problem, in a nutshell, is you are using LT. So that means that most of the solutions you'll come across are going to be lisp based and you can't use them.
    I was going to offer to offset the line for you but seeing how you are most of the way there I guess it's pointless.
  5. #5
    Full Member
    AutoCAD LT 2014
    Mar 2015
    28
    thanks anyway ..
  6. #6
    Forum Deity steven-g's Avatar
    steven-g's Computer Details
    Win 7
    Construction
    steven-g's Discipline Details
    Draughtsman
    Construction
    I work in the estimating department of a large building contractor.
    AutoCAD 2018
    May 2013
    An Englishman in Belgium
    2,165
    Would it not be possible to explode the 3dpolyline, flatten the lines, convert to polyline and join the segments, and then offset ? Providing there aren't any arc's (just straight lines) this should be an option for a macro. It's a bit unclear because you mention a curved 3dpolyline and then lines once exploded. Could you post the DWG
  7. #7
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,879
    You can PEdit a 3Dpolyline and use the Spline option on it thus creating a curved 3Dpolyline. Upon exploding it however it becomes a series of straight line segments. In a simple test I created a 10 segment 3Dpolyline. Then I applied the Spline curve option. Finally I exploded it. I now had 64 line segments.
  8. #8
    Full Member
    AutoCAD LT 2014
    Mar 2015
    28
    flatten is an express tool to the best of my knowledge. the 3d poly became lines after exploded .. once you join them again (without Flatten) they become a 3d poly again ..
    Thanks anyway
  9. #9
    Win 7
    Construction
    Draughtsman
    Construction
    AutoCAD 2018
    May 2013
    2,165
    So long as it doesn't have arc's there is a macro that we use in LT fot flattening objects, it just gives problems with some objects (like arc's)
  10. #10
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,879
    I don't believe splines support arcs when exploded only line segments.
  1. Object selection
    By hessoka in forum .NET, ObjectARX & VBA
    Last Post: 6th Jun 2014, 04:29 am
  2. Object selection
    By anp2012 in forum AutoCAD General
    Last Post: 30th Oct 2012, 09:17 am
  3. Object Selection-Gone Bad
    By stevedrew in forum AutoCAD General
    Last Post: 12th Sep 2012, 07:35 pm
  4. Trim selection & Object selection problem
    By Kurt Crim in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 12th Aug 2011, 12:19 pm
  5. object selection
    By salman in forum AutoCAD General
    Last Post: 2nd Feb 2010, 10:18 am
